yes i will open thread for that to explain everything
Nucleo F401 have crystal 8 mhz similiar to F411
(because it was used from ST-Link 2.1 Programmer which was included on it)
and info about F401 are there NUCLEO-F401RE | Mbed
i belive FEZ firmware could work simply by default on it but i have no such board since i work with only 411
@matsujirushi
i can not compile your code it give me this error
C:\TinyCLRPorts050\Main\main.cpp: In function ‘int main()’:
C:\TinyCLRPorts050\Main\main.cpp:102:55: error: too few arguments to function 'TinyCLR_Result TinyCLR_Startup_SetDebugger(const TinyCLR_Api_Info*, size_t)'
TinyCLR_Startup_SetDebugger(EXPAND(_Uart_GetApi)());
In file included from C:\TinyCLRPorts050\Main\main.cpp:15:0:
C:\TinyCLRPorts050\Core/TinyCLR.h:304:16: note: declared here
TinyCLR_Result TinyCLR_Startup_SetDebugger(const TinyCLR_Api_Info* api, size_t index);
C:\TinyCLRPorts050\Build\release\STM32F407G-DISC1\STM32F4_Startup.gcc.obj: In function Reset_Handler': (i.EntryPoint+0x18c): undefined reference tomain’
collect2.exe: error: ld returned 1 exit status
C:\Program Files (x86)\GNU Tools ARM Embedded\6 2017-q2-update\bin\arm-none-eabi-objcopy.exe: ‘C:\TinyCLRPorts050\Build\release\STM32F407G-DISC1\tinyclr.axf’: No such file
Done
@matsujirushi my mistake i copy just folder Device folder now i see also you modified and main.cpp now is OK i’m going testing now with uart i see you modified this part and i belive now we can use in both way
usb or uart
