… is a self-contained file system device. No, no system API will talk to it… it’s intended for dumber devices that have limited capability, so may not be what you need for a complex microcontroller solution.
In answer to (1), no, there is currently no support for CDC over the (inbuilt) USB connection. You’d be better off looking at a UART to USB chip/module wired to a UART and using that. Code UART
Hi Brett,
Thanks for the reply.
I have 3 more questions
I am currently testing the FEZ Lemur as well, which has a built in SD card.
It would be of great use the storage api for the FEZ, since I believe the Lemur is now a legacy product.
1] Is there any sd card adapter for the current FEZ that would utilize the API
“GHIElectronics.TinyCLR.NativeApis.STM32F4.SdCardStorageController\0”
2] if yes to question one, how would I add that api to theFEZ.
3] what is the API
“GHIElectronics.TinyCLR.NativeApis.STM32F4.InternalFlashStorageController\0”
This is a tricky question as you are looking at TinyCLR 1.0 and we are now about to release 2.0. Anyway, for your question on SD cards, the answer is here, but not all systems support SD cards.
Things are a lot more complete in coming 2.0. So stay tuned for more info.
