@ John_ghielectroncs -
I did this but no change.
@ MNO - In the new project, did you use the same code?
@ John_ghielectroncs - Hello John,
I used the same code. I will stop testing for two weeks as I leave in hollidays. See you soon.
@ MNO - If you can email the project you’re using to support at ghi… and reference this thread, we will test it here.
Hello, John,
I came back from vacations. Rests.
I solved my problem. It had two causes :
- connection to a USB 3.0 port and
- the use of a project created under W10.
By connecting to a USB 2.0 port and writing the code under W7 the debugger works. I did tests on a Panda III, and a Brainpad.
Thanks for your help.
Vacations tend to fix everything.
YES.
