I have recently been encountering some issues with the DataReader Load member. It generates a System.ArgumentOutOfRangeException when called and there is no data in the serial input stream, this is unusual as I am use to it returning 0 when there is nothing to be loaded from the input stream.
Some simple code that we can reproduce please? how often is this happened?
Here’s a simple version of my code, it should reproduce the problem. It happens pretty frequently, basically every time I run it.
public void Start()
SerialDevice serial = SerialDevice.FromId(deviceId); //For FEZ COBRA III Board
serial.BaudRate = 115200;
serial.Parity = SerialParity.None;
serial.StopBits = SerialStopBitCount.One;
serial.DataBits = 8; //Added
serial.ReadTimeout = TimeSpan.Zero;
DataReader serialReader = new DataReader(serial.InputStream);
DataWriter serialWriter = new DataWriter(serial.OutputStream);
_readDataThread = new Thread(ReadDataThread);
_readThreadAlive = true;
_readDataThread.Priority = ThreadPriority.Highest;
_readDataThread.Start();
protected void ReadDataThread()
while (_readThreadAlive)
try
if (_serialReader.Load(1) > 0)
rxBuffer = _reader.ReadByte();
catch (Exception ex)
We need exactly example that we can reproduce. Following your code, we don’t know what port you are using. Also,
_reader.ReadByte();
_serialReader.Load(1);
I don’t see any relationship between them. Anyway, as my understand about your code, we rewrite them as below and could not reproduce issue:
static Thread _readDataThread;
static bool _readThreadAlive = true;
static DataReader _serialReader;
static DataWriter _serialWriter;
static void Main()
SerialDevice serial = SerialDevice.FromId("GHIElectronics.TinyCLR.NativeApis.STM32F4.UartProvider\\0"); //For FEZ COBRA III Board
_serialReader = new DataReader(serial.InputStream);
_serialWriter = new DataWriter(serial.OutputStream);
Thread.Sleep(-1);
protected static void ReadDataThread()
try
int rxBuffer = _serialReader.ReadByte();
