It seems that everytime I try to get back into writing code for the NETMF, I run into issues. I have yet to try to do something that seems to work 100% as advertised.
A first chance exception of type ‘System.NotImplementedException’ occurred in Microsoft.SPOT.Time.dll
An unhandled exception of type ‘System.NotImplementedException’ occurred in Microsoft.SPOT.Time.dll
This is on the FEZRaptor With the simple line of code of:
This used to work (however the UDP code did not so it was broken in that regard).
I'm starting to think I need to scrap NETMF and find other solutions.
Roy
There is a list of known issues in the firmware readme file (installed with SDK) and there is the Task Tracker in community section.
But there is no information which issue/feature is planned for next SDK or when SDK release is planned.
Is the FixedTimeService mentioned a valid alternative for the raptor or is the firmware issue blocking the entite netmf timeservice? Ask this because for one I really need the correct time running on the raptor and seeing that FixedTimeService uses Timeservice just thuoght I’d ask
I tried to make it identical and complete.
In SetUtcTime, it does call TimeService.SetUtcTime because it does more than Microsoft.SPOT.Hardware.Utility.SetLocalTime. (it adjusts uptime and probably some other things) But TimeService.SetUtcTime seems to work fine.
The big fixes are (1) non-blocking and (2) generic daylight saving solution.
