I have discovered a strange problem with Timers on the G30HDR board. I have an application that needs to read analog inputs periodically (not super fast, a couple times a second at most). However, after working for about 1 hour the timer event stops firing and the inputs are no longer read.
I have read about similar problems where there is no reference to the Timer object and it gets garbage collected even though it is still running. That is not the problem here.
I started by using a System.Threading.Timer, which exhibited the problem described above. I have also tried a simple infinite “while(true)” loop with a “Thread.Sleep(1000);” statement at the end, and I have the same problem.
I have even taken all of the code for my specific application out and can recreate the problem with the simple test code included below. When I run this, the output is as shown below the code. After iteration 4264 the infinite loop stops being executed. This always occurs at 6/1/2011 1:11:34 AM. Oddly after the output stops, if I hit pause in Visual Studio, I find that the value of “DateTime.Now” in the debugger has been reset back to 6/1/2011 00:00:00, and counts up again from there. I don’t know if that is related but it seems like it could be.
@ Dave McLaughlin - Thanks. I have actually tried this approach and it does not work either. Eventually the call to “Thread.Sleep()” never returns, and the loop is never executed again. I know that sounds crazy. I need to do something that doesn’t depend on time at all…
@ DarrenUtd - I have seen this a long time ago and it was a timer overflow not being handled properly. Give us a bit of time, we will get this sorted out. No worries
@ Gus - Thanks. I’m looking forward to a solution.
I’ve been playing around with the numbers, and I found something interesting. The 1 hour 11 minute 34 second time that the timers work for corresponds to 4294 seconds. The value of “Cpu.SlowClock” on the G30 is 1 MHz. So 4294 seconds is 4,294,000,000 clock ticks, which is 2^31.9997
@ Dat - That is very unfortunate. Do you know when the next release will be? I have a product that I am selling to a customer in a few months that depends on it.
Also, exactly which products are affected by this? All G30-based? Any others?
