I have a strange bug that moreover is a problem when trying to manage threads status correctly.
My ThreadState is set to Suspended, that is what I effectively want to have, but when managing a switch/case on the several states, the revelant cas if shown to be “Running” instead of what is shown in the tooltip !!!
Does anybody ever seen such a situation ?
See attachment for more details
Have you tested this on emulator?
May be because it was running before hitting your breakpoint.
@ Gus -
Yes, and it gives something different : WaitSleepJoin | Suspended instead of Suspended…So also uncasable…
I give you my test code so that you would check if something is comming wrong…
using System.Text;
using System.IO;
public class ThreadTester
private Thread m_serverThread = null;
private static bool m_ShouldStop = false;
private void RunServer()
while (!m_ShouldStop)
Debug.Print("------------------------------Lopping...");
System.Threading.Thread.Sleep(500);
public ThreadTester()
m_serverThread = new Thread(new ThreadStart(RunServer));
public void Start()
try
switch (m_serverThread.ThreadState)
case ThreadState.Stopped :
m_serverThread.Start();
while (!m_serverThread.IsAlive) Thread.Sleep(10);
break;
case ThreadState.Unstarted:
break;
case ThreadState.Suspended:
m_serverThread.Resume();
break;
catch
if (m_serverThread != null) Stop();
public void Stop()
m_ShouldStop = true;
while (m_serverThread.IsAlive) Thread.Sleep(100);
public void Suspend()
m_serverThread.Suspend();
public string GetStatus()
case ThreadState.Stopped:
return "Stopped";
return "Unstarted";
return "Suspended";
case ThreadState.WaitSleepJoin:
return "WaitSleepJoin";
case ThreadState.Running:
return "Running";
return "Unknown";
ThreadTester _tester = new ThreadTester();
Debug.Print(_tester.GetStatus());
Thread.Sleep(2000);
_tester.Start();
Thread.Sleep(2000);
_tester.Suspend();
Thread.Sleep(2000);
_tester.Start();
Thread.Sleep(2000);
_tester.Stop();
Thread.Sleep(2000);
_tester.Start();
Thread.Sleep(2000);
_tester.Stop();
Thread.Sleep(2000);
Even if I make a loop until !IsAlive, it does not change anything…
Added some couple of states :
return "Stopped";
return "Unstarted";
return "Suspended";
return "Running";
return "Unknown";
But really sound like if there was a mapping problem between the enum and the states in code…Or even ThreadState if not safe anymore !
Full sample code corrected with IsAlive and Thread.Sleep at the end of Main, but do not change many things…
And also the same code on G120HDR give the same results…
Found debugger!
Create TS.
Loading start at a0e00000, end a0e0fc38
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: MFConsoleApplication1 (1.0.0.0) Resolving.
GC: 1msec 276192 bytes used, 7063476 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7063476 bytes
Type 17 (ASSEMBLY ): 8148 bytes
Type 1E (BINARY_BLOB_HEAD ): 267948 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’ chargé, symboles chargés.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managé) : ‘C:\Users\louis.calenda\Desktop\Intelligent Module\IntelligentModuleSolution\MFConsoleApplication1\bin\Debug\le\MFConsoleApplication1.exe’ chargé, symboles chargés.
Le thread ‘’ (0x2) s’est arrêté avec le code 0 (0x0).
Unstarted
------------------------------Lopping…
WaitSleepJoin
Unknown
WaitSleepJoin
Le thread ‘’ (0x5) s’est arrêté avec le code 0 (0x0).
Stopped
WaitSleepJoin
Le thread ‘’ (0x6) s’est arrêté avec le code 0 (0x0).
Stopped
OK, reason found !!!
When you use a ThreadSleep into a thread, or any other locking type instruction, WiatSleepJoin is also invoked !
So if you want to make some sleep in a thread, and also manage its state, you have to find another way to do…
Look at this for more explanations :
