I have been running the code below on a G30 and the program freezes on the Thread.Sleep function calls after a seemingly random amount of loops. The debugger won’t step past the call and I am at a loss as to why this is happening.
namespace NETMFBook
OutputPort RED = new OutputPort(GHI.Pins.G30.Gpio.PB8, true);
OutputPort GRN = new OutputPort(GHI.Pins.G30.Gpio.PB9, true);
GRN.Write(false);
RED.Write(false);
Thread.Sleep(500);
SPI.Configuration MyConfig =
new SPI.Configuration(Cpu.Pin.GPIO_Pin1,
false, 0, 0, false, true, 1000, SPI.SPI_module.SPI1);
SPI MySPI = new SPI(MyConfig);
byte[] tx_data = new byte[2];
byte[] rx_data = new byte[2];
int counter = 0;
byte i = 0;
Debug.Print(counter.ToString());
//Debug.Print(Debug.GC(false).ToString());
for (i = 0; i < 100; i++)
string o = i.ToString();
//Debug.Print(o);
tx_data[0] = GetNumber(i / 10);
tx_data[1] = GetNumber(i % 10);
MySPI.Write(tx_data);
Thread.Sleep(40);
RED.Write(!RED.Read());
GRN.Write(!GRN.Read());
Thread.Sleep(1000);
counter++;
public static byte GetNumber(int Number)
switch (Number)
case 0:
return 126;//254;
case 1:
return 12;//96;
case 2:
return 182;//109;
case 3:
return 158;
case 4:
return 204;
case 5:
return 218;
case 6:
return 250;
case 7:
return 14;
case 8:
return 254;
case 9:
return 222;
return 0;
