In you main app if you do nothing you will get the
The thread ‘’ has exited with code 0 (0x0).
public static void main()
Being to to VS, C# and .netmf that sound like to me it exited the main method.
if this is so, where does it then go ?
Embedded systems are meant to operate forever.
I would consider where it goes if you exit to be undefined.
But even when you start a new project and you get this default code. It gives you that exited message.
Yet its in a while loop. So what did it exit from and where did it go ?
// Blink board LED
bool ledState = false;
OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, ledState);
// Sleep for 500 milliseconds
Thread.Sleep(500);
// toggle LED state
ledState = !ledState;
led.Write(ledState);
.NET does funny things behind the scenes.
The framework may have started a thread to assist with initialization of your program. Once you program is started it can die.
On full .NET I often see threads terminating at unexpected times. I gave up worrying about it a long time ago.
The answer is in the open source .NET MF code.
