The Robot kit makes sound when I insert USB
When I first insert the USB from PC to FEZ MINI of Robot Kit.
It make loud sound "Bep, Bep,… " and the Led is blinking.
Is it the normal condition?
Lin
FEZ Mini comes with a preloaded test application that blinks the LED . so it is not related to the USB.
For the USB Beeping, you might need to install the USB debugging driver. Did you take a look at FEZ tutorial document under downloads?
Oh, I know now.
Because I Just read the manual for update the firmware of FEZ. About the driver, because I have connected the USBiz, the PC can know the FEZ Mini.
Good job 8) Tell me when you get your robot spinning around
