Okay, we are on part 3 of the Network Shootout – as well as third language denoting it, if you count English .
In this round of the Shootout, GHI will be contributing ThingSpeak results along-side @ DukeNukem as well as anyone else that would like to contribute results. We let a setup run over night and are pleased to release the results (See: Channels - ThingSpeak IoT). This was a one-off test and does not prove anything conclusively. However, I am doing the final editing of the projects for each host, and the channels listed below will be made public when the test actually commences.
If you wish to contribute to this part of the shootout, please ensure that each system will be going through [em]the same network path [/em]-- switches may be okay, but do add a possible problem point. Be sure to note network setup with the submission of results.
Each of the following setups will be running 4.3 firmware:
There was an issue with WAN->LAN connection yesterday (I think the Internet Port on the router is damaged) so I had to go this morning and grab a cross-over cable to link the switches. It will be open to the public shortly
@ James - ok buddy, this is an exciting experiment, you need to keep us updated when you mess with the setup. I think your reset counter is not working…
@ njbuch - Currently I am only playing around with the boards. This is not an official ‘reload’ of the test. I also have not changed the setup, as well as I am using Duke Nukem’s code for the cerberus test, only changing interface construction. I will let you know when the test officially resumes
Stops is death. You’ll need to track down the other threads (part one and part deux), but the network stacks on some of these boards are not entirely stable (and this is no cave).
