Hello
please anybody can let me know if the old display CP7 is again supported with the TinyCLR ?
http://old.ghielectronics.com/catalog/product/376
the tutorial http://docs.ghielectronics.com/tinyclr/tutorials/display.html is not clear (for me !)
if yes, thanks to share any init
regards
It should work, yes. You’ll just need to pull the display configuration from NETMF. There is no native touch driver though so you’ll have to port the NETMF one over.
pleases can you think a little bit about VB users? there is never any VB samples
all example, tutorial are in C#
i’m doping some test from http://old.ghielectronics.com/docs/34/graphics#3200
or http://docs.ghielectronics.com/tinyclr/tutorials/display.html
but unlucky for now
regards
The conversion between C# and VB is pretty straightforward and there are many code converters available online that can freely change between the languages. That said, multi-language tutorials are something we’re keeping an eye on, but don’t have anything there at the moment.
sure John, that’s not the biggest problem !
the link http://old.ghielectronics.com/docs/34/graphics#3200 is about NTMF and i can’t import
using GHI.Processor;
using Microsoft.SPOT.Hardware
so my question is a sample working with TinyCLR, even in C#, would be usefull !
thanks
There’s a bit of information here http://docs.ghielectronics.com/tinyclr/tutorials/display.html as you saw.
Fonts work very similar to NETMF. Add one of the two NETMF fonts to your project as a resource. Then:
var screen = Graphics.FromHdc(displayController.Hdc);
var font = Resources.GetFont(Resources.FontResources.small);
screen.DrawString("Hello", font, new SolidBrush(Color.White), 0, 50);
that’s the sample i try to use …
but unlucky, unable to translate
globally, i don’t find any help on the differents Namespaces
Brett
February 15, 2018, 8:07pm
8
Visual Studio and the solution explorer will help, no? What can’t you figure out ?
although I use .NET for many years, I’m confused!!!
i can’t find the definition and translate the simple line
displayController.ApplySettings(new ParallelDisplayControllerSettings {
Width = 480,
Height = 272,
DataFormat = DisplayDataFormat.Rgb565,
PixelClockRate = 20000000,
PixelPolarity = false,
OutputEnablePolarity = true,
OutputEnableIsFixed = false,
HorizontalFrontPorch = 2,
HorizontalBackPorch = 2,
HorizontalSyncPulseWidth = 41,
HorizontalSyncPolarity = false,
VerticalFrontPorch = 2,
VerticalBackPorch = 2,
VerticalSyncPulseWidth = 10,
VerticalSyncPolarity = false,
i can only translate it to :
displayController.ApplySettings(New DisplayControllerSettings)
can’t set the parameters of the screen !!
John,
please can you send me a short sample to write “hello world” on this CP7 screen ?
VB preferably !
thanks in advance, regards
using System.Drawing;
using GHIElectronics.TinyCLR.Devices.Display;
using TinyCLRApplication23.Properties;
namespace TinyCLRApplication23
class Program
static void Main()
var displayController = GHIElectronics.TinyCLR.Devices.Display.DisplayController.GetDefault();
displayController.ApplySettings(new LcdControllerSettings
Width = 800,
Height = 480,
HorizontalFrontPorch = 9,
OutputEnablePolarity = false,
PixelClockRate = 15000000,
screen.Clear(Color.Black);
screen.DrawString("White: Hello, world", font, new SolidBrush(Color.White), 10, 190);
screen.DrawString("Red: Hello, world", font, new SolidBrush(Color.Red), 10, 210);
screen.DrawString("Green: Hello, world", font, new SolidBrush(Color.Green), 10, 230);
screen.DrawString("Blue: Hello, world", font, new SolidBrush(Color.Blue), 10, 250);
screen.Flush();
System.Threading.Thread.Sleep(-1);
thanks Sir, but as explain, i don’t find the good translation in VB !
event if i check the syntac in the object explorer, i can’t find how translate the lines
please provide me this sample in VB !
thanks for your support, regards
http://converter.telerik.com/ is a useful tool to convert C# to VB code. For GetFont
, you need to add a font resource to your project. You can find two sample fonts in the NETMF install directory.
well i successful compile the sample now, but nothing is showed on the screen.
i’m not sure about the setting, what you show is different from that page :
http://docs.ghielectronics.com/hardware/legacy_products/gadgeteer/modules.html#display-cp7
but on that page, it is write “// these are the wrong values!” …
so which setting is ok please ?
thanks
Here is for CP7. The previous one is 7 inch NHV
class Program
static void Main()
Width = 800,
Height = 480,
HorizontalBackPorch = 46,
HorizontalFrontPorch = 16,
HorizontalSyncPolarity = true,
HorizontalSyncPulseWidth = 1,
OutputEnableIsFixed = true,
PixelClockRate = 24000000,
VerticalBackPorch = 23,
VerticalFrontPorch = 7,
VerticalSyncPolarity = true,
VerticalSyncPulseWidth = 1 }
screen.Flush();
wonderful, working now !
thanks for your patience :o)
regards
