TCP socket connection questions
I have been trying out my new wings by starting out simple and create a TCP socket server on port 23.
My goal for now is to open a telnet client and connect to my Cobra board and simply echo back what i receive. With the examples here that made starting out easy.
The only thing i am trying to figure out is if i need to put a Thread.Sleep in that main loop to allow other threads to run.
So i have the following code that i snagged from there and there and changed it.
after the socket is accepted it calls ProcessRequest()
        private void ProcessRequest()
            const Int32 c_microsecondsPerSecond = 1000000;
            // 'using' ensures that the client's socket gets closed.
            using (m_clientSocket)
                // Wait for the client request to start to arrive.
                Debug.Print("Connected...");
                byte[] buffer;
                while (Ethernet.IsCableConnected)
                    if (m_clientSocket.Poll(5 * c_microsecondsPerSecond, SelectMode.SelectRead))
                        if (m_clientSocket.Available > 0)
                            buffer = new byte[m_clientSocket.Available];
                            m_clientSocket.Receive(buffer);
                            m_clientSocket.Send(buffer);
                            Debug.Print("No Data, Connection Lost.");
                            break;
                        Debug.Print("Received Data Timed Out, Closing Connection");
                        break;
As a general rule, unless you have a really good reason not to always put a Thread.Sleep() in any loop that may run for any noticeable time. Otherwise, you’ll end up in a point where you can no longer debug and other threads can’t do anything.
Thank you.
