Hello,
I’m starting a new Project with FEZ Cobra II Net. The final product should connect to a PC as an USB HID device. That’s why I want to use the Ethernet Interface for deployment and Debugging. In VS2010 a TCP/IP Transport Option is present. What I have to do to use this Transport? Is there a specific Firmware? Or must this feature enabled through FEZConfig?
That sounds not promising. A couple of years ago a colleague has used the USBizi board for a similar Project. AFAIK the TCP Debugging was never a problem.
So, what are the Options for implementing an USB HID device with FEZ CobraII? This is still supported I assume?
