Task Tracker - Support SPI display natively in G120 and G400 platforms
I just posted Support SPI display natively in G120 and G400 platforms on Task Tracker. Feel free to discuss and make suggestions here.
Support SPI display natively in G120 and G400 platforms was updated.
Status went from Proposed to Open.
Priority went from Unassigned to Trivial.
Bumping this back up - please vote for this idea.
So, I upvoted this because it does affect my needs. I’ll have to write a driver otherwise; which would be quite hard. I’m using those i2c displays currently and they are a bit small. I will understand if it can’t be done because of NHVN commitments.
NHVN aside, this is about scalable connected devices. Where the sweet spot for SPI displays is, is certainly starting at G80, but I see that if you just want a G120E or G400 based solution for other (performance) reasons, having to reinvent the SPI display approach yourself is excessive, and if GHI can extend the reach to these families it really can help drive cost out of the other parts of a “product”.
