I just posted Schematic issue on Task Tracker. Feel free to discuss and make suggestions here.
My guess would be that schematics is correct.
The code on bit bucket is in active development and has not been officially “released” yet.
Btw, you can easily check if there is a continuity between these pins, then they are connected.
Schematic issue was updated.
Status went from Proposed to Closed.
Priority went from Unassigned to Minor.
[line]This is a bug in the create_sockets function. This pin was dissociated with a GPIO pin in a hardware revision prior to release.
This pin is now only accessible as an Analog Input and is allowed according to the current Gadgeteer standard.
This has been fixed and should be available in the repository shortly.
