I just posted Raptor+CAN_DW: only socket 10 is working on Task Tracker. Feel free to discuss and make suggestions here.
Raptor+CAN_DW: only socket 10 is working was updated.
Status went from Proposed to Open.
Priority went from Unassigned to Minor.
Hi John and Simon. This is not a minor issue for those who need 2 can bus isn’t it? or for those who need socket 10 for something else…
In the meantime, as a work around, you can edit the driver to use CAN channel 2 if you need it to.
https://www.ghielectronics.com/docs/122/gadgeteer-driver-modification
Still a MAJOR for me to use the G400. I need this working without workarounds.
Another reason to use NuGet for Gadgeteer modules. Such a bug could be fixed and deployed in half an hour.
Status went from Open to Closed.
When is the update released?
Post said next sdk few weeks
