I just posted Deployed applications do not run when Panda II powered by PC USB on Task Tracker. Feel free to discuss and make suggestions here.
Deployed applications do not run when Panda II powered by PC USB was updated.
Status went from Proposed to Closed.
@ Gus - Can you elaborate on which drivers that should be used?
I am troubleshooting and discovered that the WinUSB driver was used. I updated the driver to use GHI_NETMF_Interface.sys driver in the SDK 4.1 folder.
Win usb should be used but 4.1 doesn’t support it, meaning the old driver is needed.
