I just posted Add [Flags] attribute to SystemUpdate.SystemUpdateType enumeration on Task Tracker. Feel free to discuss and make suggestions here.
Can you please explain more?
var gaga=SystemUpdateType.Config|SystemUpdateType.Deployment;
yields gaga=12 which is not a part of the enum, thus is simply incorrect.
In the big .NET, such usage will also trick debugger, and
will print "12" instead on "Config | Deployment".
Add [Flags] attribute to SystemUpdate.SystemUpdateType enumeration was updated.
Status went from Proposed to Open.
Priority went from Unassigned to Minor.
Status went from Open to Closed.
