Hallo all.
first up huge thanks for the great community here, it has really helped a lot with my first code attempts on my new hydra.
and now to my issue… I have a T35 connected to a Hydra board and the display works fine. The only problem I am facing is that there seems to be a bit of an offset on the touch functions. I copied the Glide-4.5 keyboard example into my project and it works quite well apart from the fact that it is not always hitting the correct keys. They seem to be a bit off to the upper left side of where I press the touch screen… below are the adjustments I made to the code, but as far as I can see it looks ok… is it advised to test the touch positions, like when you calibrate a mobile device for the first time? and if so, is there any demo od how this can be achieved (I can see the bool GlideTouch.Calibrated, but no methods to Calibrate) ?
thanks in advance.
public static Keyboard InitKeyboard()
Keyboard keyboard = new Keyboard(320, 128, 3, 32, 0);
// Each view with keys in a up position.
keyboard.BitmapUp = new Bitmap[4]
Resources.GetBitmap(Resources.BitmapResources.Keyboard_320x128_Uppercase),
Resources.GetBitmap(Resources.BitmapResources.Keyboard_320x128_Lowercase),
Resources.GetBitmap(Resources.BitmapResources.Keyboard_320x128_Numbers),
Resources.GetBitmap(Resources.BitmapResources.Keyboard_320x128_Symbols)
// We must set the default key content.
string[][] keyContent = new string[4][];
// Letters
keyContent[0] = new string[10] { "q", "w", "e", "r", "t", "y", "u", "i", "o", "p" };
keyContent[1] = new string[9] { "a", "s", "d", "f", "g", "h", "j", "k", "l" };
keyContent[2] = new string[9] { Keyboard.ActionKey.ToggleCase, "z", "x", "c", "v", "b", "n", "m", Keyboard.ActionKey.Backspace };
keyContent[3] = new string[5] { Keyboard.ActionKey.ToNumbers, ",", Keyboard.ActionKey.Space, ".", Keyboard.ActionKey.Return };
keyboard.SetViewKeyContent(Keyboard.View.Letters, keyContent);
// Numbers
keyContent[0] = new string[10] { "1", "2", "3", "4", "5", "6", "7", "8", "9", "0" };
keyContent[1] = new string[10] { "@ ", "#", "$", "%", "&", "*", "-", "+", "(", ")" };
keyContent[2] = new string[9] { Keyboard.ActionKey.ToSymbols, "!", "\"", "'", ":", ";", "/", "?", Keyboard.ActionKey.Backspace };
keyContent[3] = new string[5] { Keyboard.ActionKey.ToLetters, ",", Keyboard.ActionKey.Space, ".", Keyboard.ActionKey.Return };
keyboard.SetViewKeyContent(Keyboard.View.Numbers, keyContent);
// Symbols
keyContent[0] = new string[10] { "~", "`", "|", "•", "√", "π", "÷", "×", "{", "}" };
keyContent[1] = new string[10] { Keyboard.ActionKey.Tab, "£", "¢", "€", "º", "^", "_", "=", "[", "]" };
keyContent[2] = new string[9] { Keyboard.ActionKey.ToNumbers, "™", "®", "©", "¶", "\\", "<", ">", Keyboard.ActionKey.Backspace };
keyboard.SetViewKeyContent(Keyboard.View.Symbols, keyContent);
int[][] keyWidth = new int[4][];
// Letters
keyWidth[0] = new int[10] { 32, 32, 32, 32, 32, 32, 32, 32, 32, 32 };
keyWidth[1] = new int[9] { 32, 32, 32, 32, 32, 32, 32, 32, 32 };
keyWidth[2] = new int[9] { 48, 32, 32, 32, 32, 32, 32, 32, 48 };
keyWidth[3] = new int[5] { 48, 32, 160, 32, 48 };
keyboard.SetViewKeyWidth(Keyboard.View.Letters, keyWidth);
// Numbers
keyWidth[1] = new int[10] { 32, 32, 32, 32, 32, 32, 32, 32, 32, 32 };
keyboard.SetViewKeyWidth(Keyboard.View.Numbers, keyWidth);
// Symbols
keyboard.SetViewKeyWidth(Keyboard.View.Symbols, keyWidth);
keyboard.CalculateKeys();
return keyboard;
