System.outofmemoryexception
An unhandled exception of type ‘System.OutOfMemoryException’ occurred in AForge.exe.
 COMPLEX[] Fourier;
 public void ForwardFFT()
            //Initializing Fourier Transform Array
            int i,j;
            Fourier = new COMPLEX[320 * 240];
            Output = new COMPLEX[Width*Height];
            //Copy Image Data to the Complex Array
            for (i=0;i<=Width -1;i++)
                for (j = 0; j <= Height - 1; j++)
                   // Fourier[i][j].real =(double) GreyImage[i][j];
                   // Fourier[i][j].imag = 0;
            //Calling Forward Fourier Transform
          //  Output= FFT2D( Fourier, nx, ny, 1);
            return;
when Fourier = new COMPLEX[320 * 240]; called this exception shows. how to solve
@ biren - Whats a complex?
I would imagine that it is creating an array of objects that is consuming more ram and is available for your device.
I bet reducing your memory consumption will help.
Or buy a mainboard with more memory to start with; but the real issue is you have to THINK SMALL.
@ Justin - complex is a structure.
  struct COMPLEX
        public double real, imag;
        public COMPLEX(double x, double y)
            real = x;
            imag = y;
        public float Magnitude()
            return ((float)ElzeKool.exMath.Sqrt(real * real + imag * imag));
        public float Phase()
             return ((float)ElzeKool.exMath .Atan(imag / real));
@ biren - that one line is creating 153600 doubles which will be using alot of your poor wee processors resources…
@ Brett - how to reducing memory?
@ Justin - means? please explain with some details
@ biren - a double needs 8 bytes of memory.
Complex is 2 doubles so 16 bytes of memory…
Fourier = new COMPLEX[320 * 240]; is creating an array of 76800 complex items which needs 1228800 bytes of ram - 1.17mb of ram…
Hence why you are running out of memory
@ Justin - means complex is not possible in microframework?
@ biren - Complex can still be used but not with such a large array on your board.
@ Justin - ok thanks
