Hi All,
RE: NETMF 4.1
A) When I run my code on the FEZ Cobra 480x272 it works fine (no exceptions)
b) When I run using the Microsoft Emulator I get:
invoking randomly, and code always breaks on a Glide method.
I can’t see any useful hints from other forum topics on ‘System.ObjectDisposedException’
I am using the following references in the project:
GHIElectronics.NETMF.Glide
Microsoft.SPOT.Graphics
Microsoft.SPOT.Hardware
Microsoft.SPOT.Native
Microsoft.SPOT.Tinycore
My emulator settings are provided for 480x272 LCD below:
(C:\Program Files\Microsoft .NET Micro Framework\v4.1\Tools\Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe.emulatorconfig )
<?xml version="1.0" encoding="utf-8"?>
<Emulator>
<Types>
<GpioPort>Microsoft.SPOT.Emulator.Gpio.GpioPort</GpioPort>
<LcdDisplay>Microsoft.SPOT.Emulator.Lcd.LcdDisplay</LcdDisplay>
<WinFS>Microsoft.SPOT.Emulator.FS.WindowsFileSystem</WinFS>
<AsyncWinFS>Microsoft.SPOT.Emulator.FS.AsyncWindowsFileSystem</AsyncWinFS>
<BSRegion>Microsoft.SPOT.Emulator.BlockStorage.Region</BSRegion>
<BSBlockRange>Microsoft.SPOT.Emulator.BlockStorage.BlockRange</BSBlockRange>
<BSDevice>Microsoft.SPOT.Emulator.BlockStorage.EmulatorBlockStorageDevice</BSDevice>
<RemovableBSD>Microsoft.SPOT.Emulator.BlockStorage.EmulatorRemovableBlockStorageDevice</RemovableBSD>
<NativeFS>Microsoft.SPOT.Emulator.FS.NativeFileSystem</NativeFS>
<RamManager>Microsoft.SPOT.Emulator.Memory.RamManager</RamManager>
<PhysicalSerialPort>Microsoft.SPOT.Emulator.Sample.PhysicalSerialPort, Microsoft.SPOT.Emulator.Sample.SampleEmulator</PhysicalSerialPort>
<EmulatorSerialPort>Microsoft.SPOT.Emulator.Sample.EmulatorSerialPort, Microsoft.SPOT.Emulator.Sample.SampleEmulator</EmulatorSerialPort>
</Types>
<EmulatorComponents>
<RamManager>
<Size>8388608</Size>
</RamManager>
<LcdDisplay id="mydisplay">
<Width>480</Width>
<Height>272</Height>
<BitsPerPixel>16</BitsPerPixel>
</LcdDisplay>
<PhysicalSerialPort id="COM1">
<ComPortHandle>Usart1</ComPortHandle>
<PhysicalPortName>COM1</PhysicalPortName>
<BaudRate>38400</BaudRate>
<GpioPort id="Pin_Select">
<Pin>3</Pin>
<ModesExpected>InputOutputPort</ModesExpected>
<ModesAllowed>InputOutputPort</ModesAllowed>
<Interrupt>EdgeLow</Interrupt>
<Resistor>PullUp</Resistor>
<VirtualKey>VK_SELECT</VirtualKey>
</GpioPort>
<GpioPort id="Pin_Left">
<Pin>0</Pin>
<VirtualKey>VK_LEFT</VirtualKey>
</GpioPort>
<GpioPort id="Pin_Right">
<Pin>1</Pin>
<VirtualKey>VK_RIGHT</VirtualKey>
</GpioPort>
<GpioPort id="Pin_Up">
<Pin>2</Pin>
<VirtualKey>VK_UP</VirtualKey>
</GpioPort>
<GpioPort id="Pin_Down">
<Pin>4</Pin>
<VirtualKey>VK_DOWN</VirtualKey>
</GpioPort>
<BSDevice id="OnBoardFlash">
<MaxSectorWriteTime>500</MaxSectorWriteTime>
<MaxBlockEraseTime>2000</MaxBlockEraseTime>
<PersistanceFilename>OnBoardFlash.dat</PersistanceFilename>
<BytesPerSector>2048</BytesPerSector>
<Regions>
<BSRegion>
<BytesPerBlock>131072</BytesPerBlock>
<BlockRanges>
<BSBlockRange>
<RangeType>Usage_Config</RangeType>
<StartBlock>0</StartBlock>
<BlockCount>1</BlockCount>
</BSBlockRange>
<BSBlockRange>
<RangeType>Usage_Deployment</RangeType>
<StartBlock>1</StartBlock>
<BlockCount>10</BlockCount>
</BSBlockRange>
<BSBlockRange>
<StartBlock>11</StartBlock>
</BSBlockRange>
<BSBlockRange>
<StartBlock>21</StartBlock>
</BSBlockRange>
<BSBlockRange>
<StartBlock>31</StartBlock>
</BSBlockRange>
<BSBlockRange>
<StartBlock>41</StartBlock>
</BSBlockRange>
<BSBlockRange>
<RangeType>Usage_FileSystem</RangeType>
<StartBlock>51</StartBlock>
<BlockCount>510</BlockCount>
</BSBlockRange>
<BSBlockRange>
<RangeType>Usage_Storage_A</RangeType>
<StartBlock>562</StartBlock>
</BSBlockRange>
<BSBlockRange>
<RangeType>Usage_Storage_B</RangeType>
<StartBlock>563</StartBlock>
</BSBlockRange>
</BlockRanges>
</BSRegion>
</Regions>
</BSDevice>
<NativeFS id="FATFS">
<Namespace>ROOT</Namespace>
<FileSystemName>FAT</FileSystemName>
<BlockStorageDeviceComponentId>OnBoardFlash</BlockStorageDeviceComponentId>
<VolumeId>0</VolumeId>
<Label>FATFS</Label>
<SerialNumber>100005</SerialNumber>
</NativeFS>
<RemovableBSD id="SD1">
<Namespace>SD1</Namespace>
</RemovableBSD>
<RemovableBSD id="SD2">
<Namespace>SD2</Namespace>
</RemovableBSD>
<WinFS id="WinFS">
<Namespace>WINFS</Namespace>
<BufferingStrategy>SyncIO</BufferingStrategy>
<CanRead>true</CanRead>
<CanWrite>true</CanWrite>
<CanSeek>true</CanSeek>
<Label>WinFS0</Label>
<SerialNumber>100000</SerialNumber>
<TotalSize>20000000</TotalSize>
</WinFS>
</EmulatorComponents>
</Emulator>
For the moment I am using try catch to continue test/developing but there’s something inherently wrong
Any thoughts welcome.
