The exception happens on the line:
HttpWResponse = (HttpWebResponse)(((WebRequest)HttpWRequest).GetResponse());
Here’s the output:
WiFly IP : 192.168.43.66
WiFly MAC : 00:06:66:80:4d:9f
The thread ‘’ (0x4) has exited with code 0 (0x0).
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
A first chance exception of type ‘System.Net.WebException’ occurred in System.Http.dll
I’m not seeing the error code. If I expand the exception I see it’s member variables but nothing of the form 10xxx (There’s an HResult code of 4278190080 deep in the structure but that’s it). Is there another way to get the error code?
@ scoleman2272 - We were able to reproduce your issue, however, only using your provided URL. http://www.netmftoolbox.com returned 0 bytes, as it is a redirect and the WebRequest would (as far as I know) not update the forwarding. Using the link pointed to by http://www.netmftoolbox.com (http://netmftoolbox.codeplex.com/), we encountered your issue. The issue with the original link is also present on Spider with WiFiRS21 using the original link. Changing the URL to almost anything but (for example, google.com) a proper response is sent. Code below is the Spider version.
public partial class Program
HttpWebResponse response;
HttpWebRequest request;
wifi_RS21.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(wifi_RS21.Interface);
wifi_RS21.Interface.NetworkAddressChanged += new NetworkInterfaceExtension.NetworkAddressChangedEventHandler(Interface_NetworkAddressChanged);
WiFiNetworkInfo[] infos = wifi_RS21.Interface.Scan();
foreach (WiFiNetworkInfo info in infos)
if (info.SSID == "linksys")
Debug.Print("Found linksys with " + info.RSSI.ToString() + "% signal strength.");
wifi_RS21.Interface.NetworkInterface.EnableDhcp();
wifi_RS21.Interface.Join(info, "no");
break;
void Interface_NetworkAddressChanged(object sender, EventArgs e)
if (wifi_RS21.Interface.NetworkInterface.IPAddress == "0.0.0.0")
Debug.Print("Awaiting IP Address");
Debug.Print("IP Address: " + wifi_RS21.Interface.NetworkInterface.IPAddress);
Debug.Print("Generating Request");
request = (HttpWebRequest)HttpWebRequest.Create("http://google.com");
request.Method = "GET";
request.UserAgent = "MyApp NETMF";
request.KeepAlive = false;
request.Timeout = 1000;
Debug.Print("Awaiting response...");
response = (HttpWebResponse)request.GetResponse();
Debug.Print("Done.\n" + response.ContentLength.ToString() + " bytes");
With the following output
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5
Found linksys with 68% signal strength.
IP Address: 192.168.1.129
Generating Request
Done.
219 bytes
I tried this code as close to verbatum as I could and I still get the exception
In this case:
An unhandled exception of type ‘System.Net.WebException’ occurred in System.Http.dll
In fact I get this exception no matter what I point to
The big difference is that you were using the RS21 wifi and I’m using WiFly. I’m not thinking it’s got something to do with the lower level Wifly drivers.
@ scoleman2272 - We will re-test this with a Cerberus and WiFly, however it could also be how HttpWebRequest fullfills the request. If the request tries to send out more than one request (or the server responds to more than one request) before the WiFly closes the TCP connection, there could be a collision due to the fact that the WiFly module can only have a single active connection. However, we should have more information when we re-test.
@ scoleman2272, how big is the page you are trying to get? Is it possible you are exceeding the memory limit? You might try using a really small page and see what happens.
// Creates a socket
SimpleSocket Socket = new WiFlySocket("www.netduino.com", 80, wifiBoard);
// Connects to the socket
Socket.Connect();
// Does a plain HTTP request
Socket.Send("GET / HTTP/1.1\r\n");
Socket.Send("Host: " + Socket.Hostname + "\r\n");
Socket.Send("Connection: Close\r\n");
Socket.Send("\r\n");
// Prints all received data to the debug window, until the connection is terminated and there's no data left anymore
while (Socket.IsConnected || Socket.BytesAvailable > 0)
string Text = Socket.Receive();
if (Text != "")
Debug.Print(Text);
// Closes down the socket
Socket.Close();
@ scoleman2272 - Okay, I think I see the issue. When you use a simple socket, in this manor, you are actually constructing the socket from the NETMF ToolBox driver for the RN-17x module. This is a single connection module that houses it’s own TCP/IP stack, and you will need to create code to allow the firmware to interface with the TCP/IP stack, if that is even possible with the RN-17x.
The WiFlySocket class most likely inherits from the SimpleSocket class, allowing the SimpleSocket class to function as provided by your last example.
I read all replies but still don;t understand how to solve it.
My code is
_wifi.DebugMode = true;
Debug.Print("Initializing WiFi");
_wifi.EnableDHCP();
_wifi.JoinNetwork("Z1234",0, WiFlyGSX.AuthMode.WPA2_PSK, "569326");
bool noIP = true;
while (noIP)
noIP = _wifi.LocalIP == "0.0.0.0";
System.Threading.Thread.Sleep(250);
Debug.Print("WiFly IP :" + _wifi.LocalIP);
Debug.Print("WiFly MAC :" + _wifi.MacAddress);
HttpRequest request;
request = Gadgeteer.Networking.WebClient.GetFromWeb("http://www.netmftoolbox.com");
request.ResponseReceived += new HttpRequest.ResponseHandler(request_ResponseReceived);
void request_ResponseReceived(HttpRequest sender, HttpResponse response)
string text = response.Text;
Debug.Print("***Response is received : " + text);
Debug.output
WiFly IP :10.59.1.23
WiFly MAC :00:06:66:80:3a:83
The thread ‘’ (0x5) has exited with code 0 (0x0).
An exception occured while connecting to the Internet. Please, make sure that a valid URL is used and a network connection is up.
