Hello, I keep getting the error above when trying to read from a text file located on my SD Card, for some reason it allows me to continue but it’s still annoying, I’m guessing it has something to do with either closing the Filestream or Disposing of the SDCard object, I’ve read many posts on how to use the SDCard object but all this has done is confuse me more, below is my code if anyone can spot any obvious mistakes.
public static string ReadLine(string fileName, int lineNumber)
var line = "";
var sd = new SDCard();
sd.Mount();
while (!sd.Mounted)
var fs = new FileStream(fileName, FileMode.Open, FileAccess.ReadWrite);
var lineNo = 0;
using (var sr = new StreamReader(fs))
while (sr.Peek() >= 0)
lineNo++;
line = sr.ReadLine();
if (lineNo == lineNumber)
goto DONE;
DONE:
fs.Close();
sd.Unmount();
sd.Dispose();
return "";
@ chillydk147 -
What line do you get this exception?
@ Dat - It doesn’t break inside this method, only when I return to code which called the method??
This is another message I see when pressing the break button on the error popup, no idea what it means
@ Andre - I’ve added the “Microsoft.SPOT.IO” assembly and included it as a using namespace but I still get the same cryptic message??
@ chillydk147 -
Your problem can be:
- The SD need to be reformat. I know it can work perfectly on PC but sometime need to be reformatted again.
- The path can be wrong. Missing “\SD” or something else…
and last thing to do
- Try lower clock
I think the code below is a bit better to debug.
using System.IO;
using Microsoft.SPOT.IO;
using GHI.IO;
using GHI.IO.Storage;
namespace Cerb_SD_Tester
private static OutputPort _led = new OutputPort((Cpu.Pin)(2 * 16 + 4), true); // LED
static InputPort button_ldr1 = new InputPort((Cpu.Pin)(2 * 16 + 2), false, Port.ResistorMode.PullUp); // Socket 4 - PC2 - pin 3
// Part I -> Press button to InitSD card
while (button_ldr1.Read() == true)
Thread.Sleep(500);
_led.Write(true);
Thread.Sleep(500);
_led.Write(false);
_led.Write(false);
SDCard sdPS = new SDCard();
// Mount the file system
sdPS.Mount();
VolumeInfo vol = VolumeInfo.GetVolumes()[0];
if (vol.IsFormatted == false )
Debug.Print("Formating...!");
vol.Format("FAT", 0);
Debug.Print("Formatted!");
_led.Write(true);
Debug.Print("Initialize OK....");
Debug.Print("Label = " + vol.VolumeLabel);
Debug.Print("Size = " + vol.TotalSize);
// Part II -> Press button to Write file
Thread.Sleep(50);
_led.Write(true);
Thread.Sleep(50);
_led.Write(false);
Debug.Print("Getting files and folders:");
int i;
if (vol.IsFormatted)
string rootDirectory =
VolumeInfo.GetVolumes()[0].RootDirectory;
//// For explore
string[] files = Directory.GetFiles(rootDirectory);
string[] folders = Directory.GetDirectories(rootDirectory);
Debug.Print("Files available on " + rootDirectory + ":");
for ( i = 0; i < files.Length; i++)
Debug.Print(files[i]);
Debug.Print("Folders available on " + rootDirectory + ":");
for ( i = 0; i < folders.Length; i++)
Debug.Print(folders[i]);
//Thread.Sleep(-1);
const int BLOCK_SIZE = 1*1024 ;
byte[] data = new byte[BLOCK_SIZE];
FileStream stream;
////// For Write
stream = new FileStream(rootDirectory
+ @ "\test.txt", FileMode.Create);
for (i = 0; i < BLOCK_SIZE; i++)
data[i] = (byte)(i % 0xFF);
long time_start = DateTime.Now.Ticks;
for (i = 0; i < 100; i++) // write 1M
try
stream.Write(data, 0, BLOCK_SIZE);
catch
Debug.Print(" Error at i = " + i);
if (i % 10 == 0)
Debug.Print("i== " + i);
long time_end = DateTime.Now.Ticks - time_start;
Debug.Print("Write end = " + time_end);
stream.Close();
stream.Dispose();
stream = null;
////// For read //////////////////////
+ @ "\test.txt", FileMode.Open);
// Just try first block
stream.Read(data, 0, BLOCK_SIZE);
if (data[i] != (byte)(i % 0xFF))
Debug.Print("=>>>>>>>>>>>>>>>>>>>>>>>>>>> Test Read failed!");
break;
stream.Dispose();
stream.Close();
stream = null;
Debug.Print("Read OK!");
Debug.Print("Storage is not formatted. Format on PC with FAT32/FAT16 first.");
// Unmount
sdPS.Unmount();
_led.Write(true);
Thread.Sleep(-1);
@ Dat - Thanks for the code, the SD card is formatted as FAT32, the code hits the line " Test Read failed!", its strange because if I comment this block out and let it read my code it does indeed pull out the line I need, it’s just the error message which I don’t understand.
var stream = new FileStream(fileName, FileMode.Open);
for (short i = 0; i < BLOCK_SIZE; i++)
break;
[quote] the code hits the line " Test Read failed!",
[/quote]
Which code are you using? my code or yours?
If your code then you have to check the path - file name
I can see that data is populated with 1024 bytes
@ chillydk147 -
So what exactly problem do you have now?
