I just got a FEZ Panda board, I have VS2010 with NETMF installed. I installed the GHI USB drivers and put the latest firmware on the Panda (4.1 something I beleive).
I’m a seasoned .NET developer, I’ve done some hobbyist-type stuff with sensors (using Phidgets), but I’m new to NETMF.
I checked out the samples, but couldn’t really find one that did the basics. I don’t have any input or output at the moment, so I just want to, in code A) see if I’m running in an emulator or not and B) get some basic information about the system/board/firmware/etc. Just using intellisense and trying different things, I get InvalidOperationException with just about everything I try using the emulator first.
Anyone have any good resources on how to start off with some basic output of some useful information about the current environment?
Also, I tried to add a reference to FEZPanda_GHIElectronics.NETMF.FEZ because I assume this is going to have some Panda-specific functionality, but this blows up when I run it via the emulator.
How do you make an emulator that acts like a Panda board?
The emulator will always complain that you don’t have a Panda attached if you attempt to deploy to it with the FezPanda_GHI(blah) reference added. That you can ignore. But if you attempt to reference stuff that only GHI add, then you’re not going to get much further - there really isn’t a complete method to do that (actually someone was working on emulating a Fez, did that go anywhere?).
One book I have bought that I found valuable was Jens Kuhner’s Expert .Net Micro Framework (I have the 2nd edition, found it for ~$20 new on ebay). It covers a wide range of topics and not just at Expert level but was really good at helping understand some of the basics too - but the beginners guide as Architect points out is also invaluable !
I run it in the emulator, it works fine. I bring up MFDeploy, my Panda responds to a ping. So in VS2010, I choose USB as the deployment option and “USBizi_USBizi” as the device.
When I hit F5, I only get:
[quote]------ Deploy started: Project: MFConsoleApplication3, Configuration: Debug Any CPU ------
An error has occurred. Please check your hardware========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========[/quote]
and for deployment output:
[quote]Incrementally deploying assemblies to device
Deploying assemblies for a total size of 189928 bytes
Assemblies not successfully deployed to device.
Deployment to the device was not successful.[/quote]
Any ideas why this doesn’t work? It should be this straight-forward, right??
