@ Architect:
globally my project consists of an USBizi chip beside some other hardware like an serial flash, mp3 decoder and a microcontroller on an self developed pcb (but too bad, i have no led blinking module ;D ) . The whole project (software and hardware) was stable up to now and i have never experienced problems in deploying the software. (Also while using the older versions, NETMF 3…) The strange thing is that i had no big source changes (just moved out the Text.UTF8 conversation from the code) when the deploy problem started… I have already tried to change back to the source code versions before the deploy problems… but no luck…
The size of my project’s pe file is around 64kByte (Debug Mode, “Optimize Code” enabled), i use following assemblies:
[ol]
GHIElectronics.NETFM.Hardware
GHIElectronics.NETFM.Hardware.USBizi
GHIElectronics.NETFM.IO
GHIElectronics.NETFM.System
GHIElectronics.NETFM.USBHost
Microsoft.SPOT.Hardware
Microsoft.SPOT.IO
Microsoft.SPOT.Native
mscorlib
System
System.IO
[/ol]
So i think the used code size should be in range of possible flash size, is this correct?
@ Gus:
I have erased the USBIzi flash (with Tera Term) and reprogramed a fresh firmware. Afterwards i created a simple “Hello World” program (i hope this is ok for a “empty” project?).
Deploying works fine without any problems!
I have traced the Device capabilities after a fresh firmware update:
Pinging... TinyCLR
HalSystemInfo.halVersion:
HalSystemInfo.halVendorInfo:
HalSystemInfo.oemCode: 0
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 0
HalSystemInfo.moduleSerialNumber:
HalSystemInfo.systemSerialNumber:
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.8.0
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: Dec 22 2011
SoftwareVersion.CompilerVersion: 410561
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 0
LCD.Height: 0
LCD.BitsPerPixel: 0
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
And the assembly summary after firmware update:
Reboot and Stop Command
No debugger!
Create TS.
Loading start at 4eb34, end 56d0c
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Resolving.
Total: (3092 RAM - 33236 ROM - 19134 METADATA)
DebuggingInfo = 788 bytes
Resources Files = 48 bytes ( 2 elements)
Ready.
Cannot find any entrypoint!
Done.
Waiting for debug commands...
No debugger!
Create TS.
Attaching file.
Resolving.
Ready.
Done.
Reboot and Stop Complete
and for the “Hello World” project (printed with .NET MF Deployment Tool):
No debugger!
Create TS.
Attaching file.
Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.1.2821.0) (388 RAM - 2268 ROM - 1357 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 24 bytes ( 6 elements)
MethodRef = 20 bytes ( 5 elements)
TypeDef = 40 bytes ( 5 elements)
FieldDef = 16 bytes ( 8 elements)
MethodDef = 96 bytes ( 48 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 537 bytes
Signatures = 293 bytes
ByteCode = 242 bytes
Assembly: GHIElectronics.NETMF.USBHost (4.1.8.0) (1668 RAM - 15824 ROM - 7067 METADATA)
AssemblyRef = 16 bytes ( 4 elements)
TypeRef = 92 bytes ( 23 elements)
FieldRef = 12 bytes ( 3 elements)
MethodRef = 88 bytes ( 22 elements)
TypeDef = 376 bytes ( 47 elements)
FieldDef = 280 bytes ( 139 elements)
MethodDef = 444 bytes ( 221 elements)
TypeSpec = 4 bytes ( 1 elements)
Strings = 3948 bytes
Signatures = 855 bytes
ByteCode = 4683 bytes
Assembly: GHIElectronics.NETMF.System (4.1.8.0) (488 RAM - 2496 ROM - 1465 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 48 bytes ( 12 elements)
MethodRef = 56 bytes ( 14 elements)
TypeDef = 80 bytes ( 10 elements)
FieldDef = 28 bytes ( 14 elements)
MethodDef = 84 bytes ( 41 elements)
Strings = 549 bytes
Signatures = 213 bytes
ByteCode = 349 bytes
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
TypeRef = 76 bytes ( 19 elements)
MethodRef = 112 bytes ( 28 elements)
TypeDef = 120 bytes ( 15 elements)
FieldDef = 72 bytes ( 35 elements)
MethodDef = 140 bytes ( 70 elements)
Strings = 676 bytes
Signatures = 350 bytes
ByteCode = 1295 bytes
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 80 bytes ( 20 elements)
MethodRef = 60 bytes ( 15 elements)
TypeDef = 336 bytes ( 42 elements)
FieldDef = 192 bytes ( 95 elements)
MethodDef = 224 bytes ( 111 elements)
Attributes = 48 bytes ( 6 elements)
Resources = 72 bytes ( 9 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 747 bytes
Strings = 648 bytes
Signatures = 595 bytes
ByteCode = 418 bytes
Assembly: USBizi Application (1.0.0.0) (260 RAM - 792 ROM - 379 METADATA)
TypeRef = 40 bytes ( 10 elements)
MethodRef = 28 bytes ( 7 elements)
TypeDef = 24 bytes ( 3 elements)
FieldDef = 4 bytes ( 2 elements)
MethodDef = 12 bytes ( 5 elements)
Resources = 16 bytes ( 2 elements)
Resources Data = 13 bytes
Strings = 134 bytes
Signatures = 51 bytes
ByteCode = 96 bytes
Assembly: GHIElectronics.NETMF.Hardware.USBizi (4.1.8.0) (172 RAM - 304 ROM - 95 METADATA)
TypeRef = 4 bytes ( 1 elements)
MethodRef = 4 bytes ( 1 elements)
TypeDef = 16 bytes ( 2 elements)
FieldDef = 0 bytes ( 0 elements)
MethodDef = 4 bytes ( 1 elements)
Strings = 75 bytes
Signatures = 3 bytes
ByteCode = 5 bytes
Assembly: GHIElectronics.NETMF.IO (4.1.8.0) (212 RAM - 664 ROM - 289 METADATA)
TypeRef = 12 bytes ( 3 elements)
FieldRef = 8 bytes ( 2 elements)
TypeDef = 8 bytes ( 1 elements)
MethodDef = 20 bytes ( 9 elements)
Strings = 212 bytes
Signatures = 33 bytes
ByteCode = 36 bytes
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
TypeRef = 124 bytes ( 31 elements)
FieldRef = 24 bytes ( 6 elements)
MethodRef = 120 bytes ( 30 elements)
TypeDef = 496 bytes ( 62 elements)
FieldDef = 176 bytes ( 88 elements)
MethodDef = 444 bytes ( 222 elements)
Strings = 1329 bytes
Signatures = 1067 bytes
ByteCode = 2611 bytes
Resolving.
Total: (9168 RAM - 78160 ROM - 44158 METADATA)
AssemblyRef = 80 bytes ( 20 elements)
TypeRef = 500 bytes ( 125 elements)
FieldRef = 44 bytes ( 11 elements)
MethodRef = 492 bytes ( 123 elements)
TypeDef = 2608 bytes ( 326 elements)
FieldDef = 1044 bytes ( 518 elements)
MethodDef = 3040 bytes ( 1514 elements)
DebuggingInfo = 1536 bytes
TypeSpec = 20 bytes ( 5 elements)
Resources Files = 96 bytes ( 4 elements)
Resources = 320 bytes ( 40 elements)
Resources Data = 1197 bytes
Strings = 9659 bytes
Signatures = 5586 bytes
ByteCode = 21437 bytes
Ready.
Hello World!
Done.
When i now try to deploy my project following message appears:
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 141728 bytes
Assemblies not successfully deployed to device.
Deployment to the device was not successful.
It’s strange that now around 141 kByte needed to be downloaded?
But sometimes it is possible to deploy my project (when i first hit deploy inside MSVisual Studio and afterwards power on my device), but after deploying i cannot connect to the device any more (or re-deploy). But i can get the startup summary list from the visual studio when i try to deploy again (although deploy does not finish successfully):
Attaching file.
Strings = 676 bytes
Strings = 537 bytes
Assembly: System (4.1.2821.0) (872 RAM - 5992 ROM - 3206 METADATA)
MethodRef = 172 bytes ( 43 elements)
TypeDef = 144 bytes ( 18 elements)
FieldDef = 56 bytes ( 28 elements)
MethodDef = 184 bytes ( 92 elements)
Strings = 21 bytes
Signatures = 546 bytes
ByteCode = 2635 bytes
Strings = 75 bytes
ByteCode = 5 bytes
Assembly: CarBox (1.0.0.0) (2616 RAM - 64520 ROM - 10896 METADATA)
AssemblyRef = 36 bytes ( 9 elements)
TypeRef = 268 bytes ( 67 elements)
FieldRef = 56 bytes ( 14 elements)
MethodRef = 388 bytes ( 97 elements)
TypeDef = 328 bytes ( 41 elements)
FieldDef = 348 bytes ( 173 elements)
MethodDef = 704 bytes ( 352 elements)
Resources = 24 bytes ( 3 elements)
Resources Data = 5810 bytes
Strings = 19058 bytes
Signatures = 1360 bytes
ByteCode = 28580 bytes
Strings = 212 bytes
ByteCode = 36 bytes
Assembly: Microsoft.SPOT.Net (4.1.2821.0) (704 RAM - 5060 ROM - 2452 METADATA)
TypeRef = 96 bytes ( 24 elements)
MethodRef = 76 bytes ( 19 elements)
FieldDef = 60 bytes ( 29 elements)
MethodDef = 136 bytes ( 68 elements)
Strings = 1280 bytes
Signatures = 388 bytes
ByteCode = 1204 bytes
Strings = 648 bytes
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
TypeRef = 168 bytes ( 42 elements)
FieldRef = 36 bytes ( 9 elements)
MethodRef = 392 bytes ( 98 elements)
FieldDef = 76 bytes ( 37 elements)
MethodDef = 392 bytes ( 195 elements)
TypeSpec = 8 bytes ( 2 elements)
Strings = 356 bytes
Signatures = 790 bytes
ByteCode = 6946 bytes
Assembly: GHIElectronics.NETMF.Hardware (4.1.8.0) (1268 RAM - 8732 ROM - 5109 METADATA)
TypeRef = 100 bytes ( 25 elements)
MethodRef = 104 bytes ( 26 elements)
TypeDef = 320 bytes ( 40 elements)
FieldDef = 128 bytes ( 64 elements)
MethodDef = 312 bytes ( 156 elements)
Strings = 2190 bytes
Signatures = 697 bytes
ByteCode = 1301 bytes
Strings = 549 bytes
Resolving.
Total: (15060 RAM - 174964 ROM - 71304 METADATA)
AssemblyRef = 152 bytes ( 38 elements)
TypeRef = 1168 bytes ( 292 elements)
FieldRef = 136 bytes ( 34 elements)
MethodRef = 1596 bytes ( 399 elements)
TypeDef = 3640 bytes ( 455 elements)
FieldDef = 1708 bytes ( 847 elements)
MethodDef = 4756 bytes ( 2372 elements)
DebuggingInfo = 2392 bytes
TypeSpec = 36 bytes ( 9 elements)
Resources = 328 bytes ( 41 elements)
Resources Data = 6994 bytes
Strings = 32430 bytes
Signatures = 9316 bytes
ByteCode = 62007 bytes
Ready.
So any ideas what goes wrong here?? please tell me if you need some other/more special traces!
br. Fred
