In general, the whole post is in the title.
Test code:
TestStringBuilder
static class TestStringBuilder
private static string[] _initStrings =
"*CLS",
"*ESE[ ?] <numeric>",
"*ESR?",
"*IDN?",
"*OPC[?]",
"*RST",
"*SRE[?] <numeric>",
"*STB?",
"*TST?",
"*WAI",
":FORMat:SREGister[?] ASCii|BINary|HEXadecimal|OCTal",
":SYSTem:ERRor[:NEXT]?",
":SYSTem:ERRor:ALL?",
":SYSTem:ERRor:COUNt?",
":SYSTem:ERRor:CODE[:NEXT]?",
":SYSTem:ERRor:CODE:ALL?",
":SYSTem:PROTect{1, 2}[:STATe][?] <boolean>,<string>",
":SYSTem:VERSion?",
":SYSTem:HELP:HEADers?",
":SYSTem:HELP:SYNTax? <string>",
":SYSTem:HELP:SYNTax:ALL?",
":STATus:OPERation[:EVENt]?",
":STATus:OPERation:CONDition?",
":STATus:OPERation:NTRansition[?] <numeric>",
":STATus:OPERation:PTRansition[?] <numeric>",
":STATus:OPERation:ENABle[?] <numeric>",
":STATus:QUEStionable[:EVENt]?",
":STATus:QUEStionable:CONDition?",
":STATus:QUEStionable:NTRansition[?] <numeric>",
":STATus:QUEStionable:PTRansition[?] <numeric>",
":STATus:QUEStionable:ENABle[?] <numeric>",
":STATus:PRESet"
private static readonly StringBuilder _stringBuilder;
static TestStringBuilder()
_stringBuilder = new StringBuilder();
foreach (var s in _initStrings)
_stringBuilder.Append('\n');
_stringBuilder.Append(s);
public static void Test()
string plainCorrectString = _stringBuilder.ToString();
string plainWrongString = _stringBuilder.ToString(0, _stringBuilder.Length);
PrintText(plainCorrectString.Length, plainCorrectString.Substring); // return correct text
PrintText(_stringBuilder.Length, _stringBuilder.ToString); // return wrong text
PrintText(plainWrongString.Length, plainWrongString.Substring); // return wrong text
private const int SEND_LIMIT = 128;
private delegate string ToSubstringHandler(int startIndex, int length);
private static void PrintText(int totalLength, ToSubstringHandler toSubstring)
int lengthSend;
int offset = 0;
while (offset < totalLength)
lengthSend = System.Math.Min(totalLength - offset, SEND_LIMIT);
Debug.Write(toSubstring(offset, lengthSend));
offset += lengthSend;
Results:
plainCorrectString
*CLS
*ESE[ ?]
*ESR?
*IDN?
*OPC[?]
*RST
*SRE[?]
*STB?
*TST?
*WAI
:SYSTem:ERRor:ALL?
:SYSTem:PROTect{1, 2}[:STATe][?] ,
:SYSTem:VERSion?
:STATus:PRESet
_stringBuilder
*CLS
*ESE[ ?] <T
*SRE[?] <numerGister[?] ASCii|BINary|HEXadecimal|OCTal
:SYSTem:ERRor:ALL?
:SYSTem:VERSion?
:STATus:PRESet
plainWrongString
*CLS
*ESE[ ?] <T
*SRE[?] <numerGister[?] ASCii|BINary|HEXadecimCOUNt?
:SYSTeSYNTax:ALL?
:STATus:OPERationc>
:STATus:PRESet
in line
System.Array.Copy(chunkChars, index, result, 0, charCount);
when constructing a line, the offset in the resulting array is not taken into account when passing chunks. It is always 0.
