Is there any way that I can do string.Contains() in .NETMF ?
The cheapest way is just to use .IndexOf(…) != -1
@ mcalsyn - Thanks man… I found the below code similar to your - works fine.
namespace System.Runtime.CompilerServices
[AttributeUsage(AttributeTargets.Assembly |
AttributeTargets.Class |
AttributeTargets.Method)]
public sealed class ExtensionAttribute : Attribute
//This allows creation of extension methods in the usual way:
public static class Utils
public static bool StartsWith(this string s, string value)
return s.IndexOf(value) == 0;
public static bool Contains(this string s, string value)
return s.IndexOf(value) > 0;
That code is actually incorrect at line 22. It will miss a string that contains the target pattern in the first character.
That is, (“Foo Bar Baz”).Contains(“Foo”) will return false when it should return true. Change the greater-than on line 22 to greater-than-or-equals.
And I don’t think you need the attribute class - I haven’t needed to do that in creating string extension classes, and I don’t think you need it here.
I have asked for these trivial methods to be added to netmf 4.4 to make it a bit more like the desktop.
I agree - don’t need attribute anymore (you used to)
