Hi!
Been googling the forums and the “net” but can’t seem to find any mentioning on this so I thought
I just post it here. Sorry if this is a known/RTFM kind of “bug”…
I’ll begin with the problem:
With the latest firmware loaded, updated NETMF and VS 2010 express, whenever I connect a USB
device to my FEZ Domino board, Debug.Print() stops outputting to the Output window and VS stops
trapping my breakpoints?
The board/application is still running though, as my testcode also “communicates” via “blinkenlights”
And this continues to work, so I know an event is triggered both at connect and disconnect and that
my eventhandlers are being called.
Solution: If at this point I go into VS and choose “Debug->Break All”, that still works! I break somewhere in my code.
If I now choose: Continue (F5), Debug.Print() and breakpoints starts to work again as intended…
I was wondering if anyone else noticed this behaviour? I am relativly new to my “board”, but I am
pretty sure this used to work without a hitch before…
I have run USB Host related examples from the Tutorials just to make sure, but they too give me
the results described above…
If requested, I’ll post my testcode, but I’ll wait in case this is an “easy fix”/config-mistake on my
part…
Best Regards!
/Stefan
