Hello,
I want to run the mIP stack with the ENC module on my STM32F429 Disco. Can anybody help me with the pin assignments? I am not sure about which pins I can use for one of the five SPI…
This does not work:
case InterfaceProfile.STM32F429I_DISCO:
Cpu.Pin SPI1_SCK = (Cpu.Pin) 5; //Stm32F429IDisco.Pins.PA5;
Cpu.Pin SPI1_MISO = (Cpu.Pin) 6; //Stm32F429IDisco.Pins.PA6;
Cpu.Pin SPI1_MOSI = (Cpu.Pin) 7; //Stm32F429IDisco.Pins.PA7;
Cpu.Pin EXT_INT = (Cpu.Pin) 9;//Stm32F429IDisco.Pins.PA9;
Cpu.Pin cs = (Cpu.Pin) 10;//Stm32F429IDisco.Pins.PA10;
SPI.Configuration config = new SPI.Configuration(SPI1_SCK, false, 1, 1, false, true, 4000, (SPI.SPI_module)1);
Start(MacAddress, name, SPI.SPI_module.SPI1, EXT_INT, cs);
break;
Later on in the mIP code the interrrupt port is set as follows:
public ENC28J60Driver(Cpu.Pin irqPin, Cpu.Pin csPin, SPI.SPI_module spiModule)
irq = new InterruptPort(irqPin, true, Port.ResistorMode.PullDown, Port.InterruptMode.InterruptEdgeLevelLow);
irq.OnInterrupt += new NativeEventHandler(irq_OnInterrupt);
Maybe the interrupt mode is wrong here?
Any ideas?
Thanks a lot.
