SSL to Azure Service Bus
I have done some searching and I can’t find a definitive answer.
Can .NET MF handle the necessary SSL/TLS communications to talk to the Azure Service bus natively? Referencing the “Internet of Things” article here: http://msdn.microsoft.com/en-us/magazine/jj190807.aspx it appears that version 4.2 should be able to handle it.
Has anyone successfully done it? I see most people using the cloud with MF devices set up a web role to receive the unencrypted data. Because of the security requirements for the project I would much rather go directly to the Service Bus using SSL.
I know of someone who used Azure service. It should work with SSL as well.
I believe SSL is still only supported on GHI’s premium boards. So, make sure the mainboard you get has support.
i use the Azure db to store data from some devices without SSL.
you need to have a web service relay the data using odata.
here is a tut on the topic
http://msdn.microsoft.com/en-us/data/gg192994
I’ve done a project where data was send to a (tcp) socket server on a azure host and db store with XTEA encryption. Client side was a fez spider.
I can confirm that it is possible to talk directly to the Azure Service bus using a G120 with mf 4.2.
My app is getting the access token from the Azure Access Control Service. It then uses SSL to send a message to a Service Bus topic. The message is read back using a Service Bus Topic Subscription.
Right now my code is a bit messy but when it’s cleaned up I will post.
Yes please share your code.
any more progress on this?
