Square waveform generator
Hello,
I am doing a project to control a stepper motor (FEZ mini). I need to have a pulse train of 25kHz, which can be implemented with PWM easily. My problem is that I want to specify the amount of pulses to generate in stead of a continuous pulsetrain. Any suggestions would be welcome.
Thanks,
Erik (big fan of FEZ Panda and mini)
Check OutputCompare class in the documentation.
http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation/html/70a79f9b-7fc2-ac38-2430-001d4a3c056c.htm
Seems to be exactly what I was looking for! Thanks!!!
You are welcome!
One thing to be aware of when using OutputCompare with Gadgeteer. OutputCompare is a part of GHI’s premium libraries, and the only available Gadgeteer mainboard that supports this feature (currently, at least) is the FEZ Spider. I use OutputCompare to generate a carrier frequency for my IR LED Array module, and it makes the code very simple, but the downside is that the module won’t work on Hydra or Cerberus/Cerbuino Bee/Cerb40.
Ok, so I won’t be able to use this on FEZ mini? Could a combination of counter/PWM work? Something like generating a PWM and let a hardware counter generate an interrupt at the desired amount of pulses?
Erik
FEZ Mini/Panda/Domino/PandaII/Rhino/Cobra will work fine. :smiley:
@ Architect - Yes, I just tried it and it is just what I needed!
@ erikhaverkamp - Architect is correct. To be clear, I was speaking particularly of .NET Gadgeteer mainboards. Since this forum is Gadgeteer-specific, I wanted to make sure you were aware of that.
@ devhammer - thanks, could you explain to me why FEZ is not gadgeteer? I seem to miss this concept, I am sorry…
@ erikhaverkamp -
Check these two pages:
http://www.ghielectronics.com/offers/
http://www.ghielectronics.com/catalog/compare/
thanks, getting more clear now… next time I will post in FEZ
