```cs
try
_connection.Open();
string sqlString = "VACUUM";
var command = new SQLiteCommand(sqlString , _connection);
command.ExecuteNonQuery();
catch (Exception e)
SharedInterfaces.Logger.Instance.LogException(e);
result = false;
I get the following exception:
#### Exception GHIElectronics.NETMF.SQLite.SQLiteException - 0x00000000 (6) ####
#### Message: Could not execute SQL statement.
#### GHIElectronics.NETMF.SQLite.Database::ExecuteNonQuery [IP: 0022] ####
#### BreakContinue.Data.SQLite.SQLiteConnection::RunNonQuery [IP: 001b] ####
#### BreakContinue.Data.SQLite.SQLiteCommand::ExecuteNonQuery [IP: 0021] ####
A first chance exception of type 'GHIElectronics.NETMF.SQLite.SQLiteException' occurred in GHIElectronics.NETMF.SQLite.dll
Is the VACUUM not a supported command in GHIElectronics.NETMF.SQLite? auto_vacuum (Pragma statements supported by SQLite) seems to be working fine. If so is there an alternative to keep the databse small and defragmented?
@ John - I tried running the GHIElectronics.NETMF.SQLite library with a small program.
Here’s the code:
using GHIElectronics.NETMF.SQLite;
namespace GHIMFVACUUMTEST
var database = new Database();
try
database.Open(":memory:");
database.ExecuteNonQuery("CREATE Table Temperature(Room TEXT, Time INTEGER, Value DOUBLE)");
database.ExecuteNonQuery("INSERT INTO Temperature (Room, Time, Value) VALUES ('Kitchen', 010000, 4423)");
database.ExecuteNonQuery("INSERT INTO Temperature (Room, Time, Value) VALUES ('Living Room', 053000, 9300)");
database.ExecuteNonQuery("VACUUM");
catch (Exception ex)
string err = Database.GetLastError();
Debug.Print("Error message: " + err);
Unfortunately, the result is the same:
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
#### Exception GHIElectronics.NETMF.SQLite.SQLiteException - 0x00000000 (1) ####
#### GHIMFVACUUMTEST.Program::Main [IP: 002d] ####
Error message:
@ istee - It looks like you’re using an older version of our SDK. I tried with our latest SDK and the command still didn’t work. We will take a look and see if we can find anything.
