I just bought Spider and a T35 screen. Connected T, R, G, B, power up Spider via usa. Cut and paste the “Simple Example” code, it works fine on Simulator, then deploy to SPider, nothing shows up on the T35. put a break point in the code, it works fine step by step.
Did i get a T35 DOA? or is there further troubleshooting i can do? Thanks,
The Spider ships with the display disabled. You should create a Gadgeteer project, add the T35 module to it and then deploy. The first deploy will activate the display module.
Make sure you the display via gadgeteer designer… Build and deploy as Mike said…
