I’ve got a simple problem: my Spider-Board isn’t recognized via USB (plugging in the Cerberus works fine).
What can I do?
Regards,
Sascha
What can I do?
Regards,
Sascha
What do you see in the device manager?
Did you try a power pack or a powered hub?
Welcome to the community.
Thanks for the warm welcome and fast reply.
When plugging in the Spider-Board, the GHI NETMF Interface shows for about a second in the device-manager and disappears again.
The board is connected via a powered USB-Hub.
@ SaschaSchwegelbauer - Do you have an application deployed to the board?
@ John I don’t know, it’s been laying around for a few months.
Actually, it looks like the Spider is rebooting permanently (USB connection comes up and drops away after a second, comes up again… and so on).
Update: I have disconnected all Extensions (except USB-Power) and now the GHI NETMF Interface stays visible.
In VS, it’s now present named “EMX_Gadgeteer”
Update2: after reconnecting modulewise, it looks like the WiFi RS21 module is responsible for the boot-loop.
@ SaschaSchwegelbauer - If you erase the application and then connect the Wi-Fi module only, does it still reboot?
Edit: sorry, I used a bad version of MFDeploy (did a download directly from Microsoft) - the version out of the framework works.
@ John - after erasing the Spider, the USB-connection is stable with connected wifi-module
