Hi All,
I am developing an application for a while and so far so good, I was able to implement network communication, SD card etc. Now I am trying to connect T43 display and it seems that something is wrong. I used FEZ config to update LCD settings, after reboot displays “G120, Version: 4.3.7.10, Debug: USB1, LCD: 480:272”. However every time I want to debug the application I get
"The debugging target and the debugger engine failed to initialize because of unspecified device errors.
The debugger engine thread has terminated unexpectedly with error ‘Could not reconnect to the debugging target after rebooting it.’.
However when I deploy the application then I can see graphics on the display but application is not responsive - even reset button doesn’t work. When I change LCD settings back to other everything is fine (without display of course).
I have tested another Spider 2 board and DP power module, also tried TE35 display but the problem remains.
using (var lcd = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight))
lcd.DrawLine(Colors.Green, 1, 20, 20, 40, 40);
lcd.DrawEllipse(Colors.Blue, 5, 5, 5, 5);
lcd.Flush();
Thread.Sleep(10000);
