Hey, I’m trying to use the fez panda to connect to the AD5206 digital potentiometer, basically attempting to replicate a project that was using the arduino to do the same thing but I’m getting caught up doing the configuration of SPI. Im not really sure what all the configuration elements are for or how they may relate to using the AD5206.
Here is the project I’m trying to copy: http://www.arduino.cc/en/Tutorial/SPIDigitalPot
The cs pin and the module I think I understand, but what about the other options in SPI configuration?
What does it mean when it says “using SPI1 in code is using SPI0 on the processor”? If the fez panda seems to have just the SPI1 should I use SPI2 when referring to it in code?
thanks for the replies guys, the ebook answers most of my questions except i am still struggling understanding the necessary WriteRead(). if i need to write 2 bytes (one for the address and one for the value) to the digital potentiometer do i need to just use a byte array like:
byte[] tx_data = new byte[2];
tx_data[0] = (byte)0x00;//digipot address (pot 1)
tx_data[1] = (byte)0xFF;//value to put pot (255 max)
byte[] rx_data = new byte[2];//does the length of this array matter?
MySPI.WriteRead(tx_data, rx_data);
i am assuming that using the WriteRead like this gets you away from having to set the CS (does it in the background, getting it from config?), so that you are just focused on the data you are sending. is that right?
[quote]i am assuming that using the WriteRead like this gets you away from having to set the CS (does it in the background, getting it from config?), so that you are just focused on the data you are sending. is that right?
[/quote]
The info on SPI at [url]http://www.microframeworkprojects.com/index.php?title=Serial_Interfaces#SPI[/url] is actually quite helpful here.
SPI transactions are always write followed by read; so WriteRead does lots of things in the middle, but that includes setting the appropriate CS line and toggling the CLK while first pushing bits out and then reading bits in; In the distant past (you know, those 8-bit uC’s that were programmed with compiled C or ASM) you’d do the CS yourself as well as the writing/reading bits onto the MOSI/MISO lines and take care of timing; now netmf does it all for you.
That also goes to answer your “how big is my RX array” question too, and confirms the approach you’re using looks right.
why does it assume that there must always be a read? that seems unusual especially since there are devices like the AD5206 dont even have a MISO type of pin (only SDI which, correct me if im wrong, is the MOSI)? why dint they write a Write() method alone instead of coupling it with the read?
I think you misunderstand. That seems like a core part of the way SPI works. There is always a read associated with a write, even if you discard the data that comes back. Each device handles that differently; some give you a status message, some nothing; you need to check the devices’ datasheet.
SPI is also an often mis-used method of serial communications to something that is not really an SPI device but behaves similarly, using a clocking signal and data signal. If you look at your data sheet, it doesn’t say it’s an SPI device it says SPI-compatble. That’s why it has SDI and no SDO, and why the writeread for you means not a lot. But if you want to use SPI you need to keep using it that way; even if nothing comes back for you.
Bret is right, SPI works by clocking data both ways at the same time. That is how it works. Even if your device really has nothing to say the SPI transceiver is still looking at the input line.
ok, but how do i determine what the byte array should be for a device? my first example was using 2 bytes, ive seen other docs that say “send address then value”, but the documentation for the device for the device says an
[quote]11-
bit serial data word into the SDI (Serial Data Input) pin. The
format of this data word is three address bits, MSB first, followed
by eight data bits, MSB first. [/quote]
the WriteRead() only takes byte arrays. can someone tanslate? whats it looking for?
you’re going to have to deal with the bit structure yourself.
SPI works with 8-bits of data.
You’re going to combine the “address” and the first of your bits into your first byte, then deal with the next 3 bits into the next byte.
Or you could do this a different way, it seems that you don’t need strict timing (from my real quick look at the data sheet; not considering your application) so you could bit-bang this yourself.
Or now RLP is more accessable, you could write a 11-bit SPI interface just for this kind of device.
ok, so what you are saying is that instead of 2 individual bytes each containing the address and the value, they are instead both squeezed mostly into the first byte with 3 bits in the second byte to make 11 total bits in 2 bytes? like this:
zero (0) resistance on pot1 00000000 as 0x00 00000000 as 0x00
full (255) resistance on pot1 00011111 as 0x1F 11100000 as 0xE0
because the address can only be 0-5 so it only needs the first 3 bits to represent the address and those bits are combined with the first 5 bits of the value to make the first byte. the second byte is made of the last 3 bits of the value with 5 zeros added to complete the full second byte? sorry if i sound like an idiot but this is a stretch from the web/db programming i am used to…
