change 0x18 to 0x38
GetParam = 0x20
ConfigRegister =0x18
0x38 =GetParam | ConfigRegister
change 0x18 to 0x38
GetParam = 0x20
YATTA!
PrintBuffer(WriteRead(new byte[] { 0x38, 0, 0 })); ///GetParam [CONFIG] Thank you Jesus, returns 2E 88!
@ Arch, man if I could give you EXP points I would give you 1K of mine!
@ Gus, could you make that happen?
There is no need.
You just have to read carefully through the datasheet. Sometimes you need to read couple of times.
You are welcome.
A couple of times? I lost count of how many times Ive read the thing.
Once this driver is complete, the L6460 is going to make an awesome addition to Gadgeteer.
Why the sad face? It appears that is the case
So I’m code complete on porting the driver, now it’s to test it out. Going to post it on the code wiki; if i can figure out how.
Gus would never encourage bashing of other products here. Even competing ones.
@ ian, kewlio
If anyone is intrested the beta driver is here: http://code.tinyclr.com/project/415/l6470-beta-ported-device-driver/
Night night.
Cool. Now, finish that CNC! ;D
@ Arch, Yes sir.
Just to conclude this post. the driver that I posted over in code works, and is able to run my stepper motor.
Good job! Is CNC done?
Nope, cnc not done yet. Next step it to design and build the driver’s circuit board.
