While working through some speed issues trying to read multiple I2C sensors I have come to some interesting findings.
The step up is NETMF 4.4 running on an STM32F405 sampling an ADXL355 3 axis accel, a MCP9803 temp sensor and a MS5637 pressure sensor.
The legacy code loop reading the sensors is maxing out at around 56 Hz which seems a little tardy.
After turning on Debug.EnableGCMessages(true);
there was a glaring issue in that the GC was running like a ferret high on cocaine which was of course slowing down the reading of the sensors.
The code for the 3 sensors use the very handy AbstractI2CDevice class to help manage the multiple devices on the one bus. The issue is that the way it is written it creates a lot of GC calls.
Eg:
public byte[] Read(byte addressToReadFrom, int responseLength = 1)
var buffer = new byte[responseLength];
I2CDevice.I2CTransaction[] transaction;
transaction = new I2CDevice.I2CTransaction[]
I2CDevice.CreateWriteTransaction(new byte[] { addressToReadFrom }),
I2CDevice.CreateReadTransaction(buffer)
int result = I2CBus.Execute(myConfig, transaction, Timeout);
return buffer;
Each Read creates new byte[]’s and int’s etc which makes the GC go wild.
So a quick change was to create a reusable xAction object
public byte[] Read(byte[] addressToReadFrom, byte[] data)
xAction[0] = I2CDevice.CreateWriteTransaction(addressToReadFrom);
xAction[1] = I2CDevice.CreateReadTransaction(data);
I2CBus.Execute(myConfig, xAction, Timeout);
return data;
Now the interesting thing here is that the GC was now running only occasionally but was not releasing any resources – ie the output was always the same.
Hmm…
Calls to
and
Are the culprit which is interesting in that the GC doesn’t seem to do much with them but was running every 5-10 secs.
So….
Creating static I2CDevice.CreateWriteTransaction’s
in each sensor driver and running
public byte[] Read(I2CDevice.I2CTransaction[] xAction, int index = 1)
return xAction[index].Buffer;
Causes zero calls to the GC
Net result?
Sensors are now running at 1200 Hz
