Special character in XML?
Hi
I tested the character amp; in the glide’s xml and it works.
But #233; or eacute; dont work !!
How can I insert new special characters in the glide lib ? (I searched in the code but I didnt find where there is the magic code to replace amp; by &)
thanks
Karima
I found : the tinyFonts of Glide have not the french characters.
Solution if you speak french : you can replace directly the old file droid_regxx.tinyfnt by my files :
http://www.tinyclr.com/codeshare/entry/575
other solution : create your tinyfont with this tool and insert your characters :
http://informatix.miloush.net/microframework/Utilities/TinyFontTool.aspx
TFConvert is in the folder : C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Tools
Bye
Karima
Thanks for update and posting the fonts.
