ged
1
Will you be open sourcing the source code ?
I read that the source code for the .NET Microsoft framework was open sourced back in Nov, 2009
Does anyone know where this is ??
I want to write various wireless protocol Rx and TX libraries for Fez and need to examine the code to see how its done.
If you are using FEZ then you do not need the code, this is what GHI does, port the code and maintain it.
If you need the code to port to your processor then you can but this is not the right place to get help.
See http://www.microsoft.com/netmf/default.mspx
The porting kit (source codes are here, for NETMF not FEZ) http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=16fa5d31-a583-4c0d-af74-f4d5e235d5bc
The ebook explains what is “porting” and “using” NETMF
