I just got a board, connected and updated the firmware etc.
But, the simple example in the Beginnser guide simply does not work. I can not declare an ‘OutputPort’, the class is unrecognised. I have tried to add references to everything, but still no luck.
What assembly shall I reference?
What namespace shall I use?
I am using the april 26 release with version 4.0.2.0
I believe they have released a new firmware. 4.0.3.0 is what is shows up as. Either way if you post upp the code you are trying to do we can help by looking at it.
I have followed the instructions correctly, as far as I can see.
However, I installed the development chain on another machine, and there it seems to work. On the new machine I installed the 1.0.5 version, May 21.
It seems that the things needed are:
Add a reference to ‘Microsoft.SPOT.Hardware’
Use the namespace ‘using MIcrosoft.SPOT.Hardware’
I shall upgrade my other machine to the latest version and see if I can make it to work in that one also.
Chimpanzee: I dont see that the firmware can be an issue here? My problem is with compiling. I guess that firmware mismatch should only fail when running on the hardware?
[quote]Chimpanzee: I dont see that the firmware can be an issue here? My problem is with compiling. I guess that firmware mismatch should only fail when running on the hardware?
[/quote]
Possible but if you are starting out then you do not want to guess things out or you will get lost.
