hi,
I’m trying to test arduino ethernet shield with panda II card. I just try the sample code given in the tutorial.
using System.Text;
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
using Socket = GHIElectronics.NETMF.Net.Sockets.Socket;
/// <summary>
/// This is a simple web server. Given a request, it returns an HTML document.
/// The same document is returned for all requests and no parsing of
/// the request is done.
/// </summary>
public static class MySocketServer
const Int32 c_port = 80;
byte[] ip = { 172, 17, 210, 200 };
byte[] subnet = { 255, 255, 0, 0 };
byte[] gateway = { 172, 17, 0, 1 };
byte[] mac = { 0x00, 0x26, 0x1C, 0x7B, 0x29,0xE8 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1,
(Cpu.Pin)FEZ_Pin.Digital.Di10,
(Cpu.Pin)FEZ_Pin.Digital.Di9, true);
try
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
NetworkInterface.EnableStaticDns(new byte[] { 172, 17, 0, 1 });
Socket server = new Socket(AddressFamily.InterNetwork,
SocketType.Stream, ProtocolType.Tcp);
// IPEndPoint localEndPoint = new IPEndPoint(IPAddress.Any, c_port);
IPAddress hostIPAddress = IPAddress.Parse("172.17.210.200");
IPEndPoint localEndPoint = new IPEndPoint(hostIPAddress, c_port);
server.Bind(localEndPoint);
server.Listen(1);
// Wait for a client to connect.
[b] Socket clientSocket = server.Accept();// problem here[/b]
// Process the client request. true means asynchronous.
new ProcessClientRequest(clientSocket, true);
catch (Exception e)
Debug.Print(e.ToString());
/// <summary>
/// Processes a client request.
/// </summary>
internal sealed class ProcessClientRequest
private Socket m_clientSocket;
/// <summary>
/// The constructor calls another method to handle the request,
/// but can optionally do so in a new thread.
/// </summary>
/// <param name="clientSocket"></param>
/// <param name="asynchronously"></param>
public ProcessClientRequest(Socket clientSocket,
Boolean asynchronously)
m_clientSocket = clientSocket;
if (asynchronously)
// Spawn a new thread to handle the request.
new Thread(ProcessRequest).Start();
else ProcessRequest();
/// <summary>
/// Processes the request.
/// </summary>
private void ProcessRequest()
const Int32 c_microsecondsPerSecond = 1000000;
// 'using' ensures that the client's socket gets closed.
using (m_clientSocket)
// Wait for the client request to start to arrive.
Byte[] buffer = new Byte[1024];
if (m_clientSocket.Poll(5 * c_microsecondsPerSecond,
SelectMode.SelectRead))
// If 0 bytes in buffer,
// then the connection has been closed,
// reset, or terminated.
if (m_clientSocket.Available == 0)
return;
// Read the first chunk of the request
// (we don't actually do anything with it).
Int32 bytesRead = m_clientSocket.Receive(buffer,
m_clientSocket.Available, SocketFlags.None);
// Return a static HTML document to the client.
String s =
"HTTP/1.1 200 OK\r\nContent-Type: text/html; charset=utf-8\r\n\r\n<html><head><title>.NET Micro Framework Web Server on USBizi Chipset </title></head>"
+ "<body><bold><a href=\"http://www.tinyclr.com/\">Learn more about the .NET Micro Framework with FEZ by clicking here</a></bold></body></html>";
byte[] buf = Encoding.UTF8.GetBytes(s);
int offset = 0;
int ret = 0;
int len = buf.Length;
while (len > 0)
ret = m_clientSocket.Send(buf, offset, len,
SocketFlags.None);
len -= ret;
offset += ret;
m_clientSocket.Close();
But the call to function Accept fail. I have inserted a try catch to intercept exception. So the message is:
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: Fail[invalid ip,port]
I’ve replaced IPAddress.Any by the IP address of the card but without result.
What can I do?
Thank you
Joe: I fixed the MAC address
