Rebooting…
Done.
Create TS.
Loading start at 4ebac, end 56d84
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Attaching deployed file.
Assembly: GHIElectronics.NETMF.W5100.Http (4.1.7.0) (2856 RAM - 35312 ROM - 12312 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 212 bytes ( 53 elements)
FieldRef = 8 bytes ( 2 elements)
MethodRef = 540 bytes ( 135 elements)
TypeDef = 408 bytes ( 51 elements)
FieldDef = 336 bytes ( 168 elements)
MethodDef = 804 bytes ( 402 elements)
TypeSpec = 4 bytes ( 1 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 8391 bytes
Signatures = 1764 bytes
ByteCode = 14483 bytes
Assembly: FEZ Panda II Application1 (1.0.0.0) (412 RAM - 2088 ROM - 844 METADATA)
AssemblyRef = 20 bytes ( 5 elements)
TypeRef = 96 bytes ( 24 elements)
MethodRef = 84 bytes ( 21 elements)
TypeDef = 40 bytes ( 5 elements)
FieldDef = 16 bytes ( 7 elements)
MethodDef = 12 bytes ( 5 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 16 bytes ( 2 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 13 bytes
Strings = 754 bytes
Signatures = 168 bytes
ByteCode = 307 bytes
Assembly: GHIElectronics.NETMF.System (4.1.7.0) (488 RAM - 2496 ROM - 1465 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 48 bytes ( 12 elements)
MethodRef = 56 bytes ( 14 elements)
TypeDef = 80 bytes ( 10 elements)
FieldDef = 28 bytes ( 14 elements)
MethodDef = 84 bytes ( 41 elements)
Strings = 549 bytes
Signatures = 213 bytes
ByteCode = 349 bytes
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
TypeRef = 124 bytes ( 31 elements)
FieldRef = 24 bytes ( 6 elements)
MethodRef = 120 bytes ( 30 elements)
TypeDef = 496 bytes ( 62 elements)
FieldDef = 176 bytes ( 88 elements)
MethodDef = 444 bytes ( 222 elements)
Strings = 1329 bytes
Signatures = 1067 bytes
ByteCode = 2611 bytes
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 80 bytes ( 20 elements)
MethodRef = 60 bytes ( 15 elements)
TypeDef = 336 bytes ( 42 elements)
FieldDef = 192 bytes ( 95 elements)
MethodDef = 224 bytes ( 111 elements)
Attributes = 48 bytes ( 6 elements)
Resources = 72 bytes ( 9 elements)
Resources Data = 747 bytes
Strings = 648 bytes
Signatures = 595 bytes
ByteCode = 418 bytes
Assembly: GHIElectronics.NETMF.Hardware (4.1.7.0) (1268 RAM - 8732 ROM - 5109 METADATA)
TypeRef = 100 bytes ( 25 elements)
MethodRef = 104 bytes ( 26 elements)
TypeDef = 320 bytes ( 40 elements)
FieldDef = 128 bytes ( 64 elements)
MethodDef = 312 bytes ( 156 elements)
Strings = 2190 bytes
Signatures = 697 bytes
ByteCode = 1301 bytes
Assembly: GHIElectronics.NETMF.W5100 (4.1.7.0) (1028 RAM - 11556 ROM - 4106 METADATA)
MethodRef = 132 bytes ( 33 elements)
TypeDef = 192 bytes ( 24 elements)
FieldDef = 88 bytes ( 43 elements)
MethodDef = 244 bytes ( 122 elements)
Strings = 1450 bytes
Signatures = 734 bytes
ByteCode = 5872 bytes
Assembly: FEZPanda_II_GHIElectronics.NETMF.FEZ (4.1.7.0) (304 RAM - 904 ROM - 495 METADATA)
TypeRef = 44 bytes ( 11 elements)
MethodRef = 20 bytes ( 5 elements)
TypeDef = 72 bytes ( 9 elements)
FieldDef = 12 bytes ( 6 elements)
MethodDef = 4 bytes ( 2 elements)
Strings = 182 bytes
Signatures = 35 bytes
ByteCode = 98 bytes
Resolving.
Total: (11268 RAM - 112280 ROM - 55315 METADATA)
AssemblyRef = 88 bytes ( 22 elements)
TypeRef = 804 bytes ( 201 elements)
FieldRef = 32 bytes ( 8 elements)
MethodRef = 1116 bytes ( 279 elements)
TypeDef = 3056 bytes ( 382 elements)
FieldDef = 1248 bytes ( 620 elements)
MethodDef = 3700 bytes ( 1847 elements)
DebuggingInfo = 1864 bytes
TypeSpec = 20 bytes ( 5 elements)
Resources Files = 96 bytes ( 4 elements)
Resources = 320 bytes ( 40 elements)
Resources Data = 1197 bytes
Strings = 17044 bytes
Signatures = 7399 bytes
ByteCode = 37141 bytes
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.W5100.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.W5100.Http.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Users\Modified(took out my name)\Desktop\FEZ Panda II HTTP\FEZ Panda II Application1\bin\Debug\le\FEZ Panda II Application1.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\FEZPanda_II_GHIElectronics.NETMF.FEZ.dll’
