Printing on the top half of the case for the ArMF Imbue has begun.
Yeah, I know the KickStarter is dead in the water, but I still have a couple on hand and darn it they will have awesome cases.
Here it is!
The heated bed had some temp variants so thereās a bit of warping on one side but it still works and Iām definitely keeping this for one of the Imbues to remember my 1st 3D design & print.
Even includes SD & power switch slots.
Cool. Iām jealous. I need a 3D printer!!!
How is the board attached? Show us the other side.
The hex bolts from GHI attach it. Iāll upload some new stuff Sunday/Monday. Going to do some minor updates to this case for the second one and create a case for my scrolling LED Matrix sign powered by the Cerberus with LiPo
SKW what 3D app are you using?
At the office I have a plugin for you to export STL out of sketchup (FREE) if you are interested.
@ Jason - Thatās exactly what Iām using
Iām still having a few issues with temperature variations on the heated bed. Itās something that wonāt affect most people/prints but Iāve got a case that takes up 90%+ of the width.
Pumping the heat up to 100C on the bed hopefully that will stop the warping Iām getting in one cornerā¦other than that the prints have been amazing.
Hereās a look at the MiniNuke Mark IIIās top case with interchangeable side plates. The bottom will have mounts ever inch or so to make swapping modules easy.
So you are exporting out of Sketch-up as a STL?
Correct.
Iāve still been having some issues with the edges but Iāll be trying the painters tape & hair spray methods today to hopefully get it to stick properly.
Iām very eager to have nice cases for all this awesome GHI gear Iāve got laying around.
What kind of issues are you having with the edges? In Sketch up or printing?
@ Jason, it was a printing issue. Tried flat corners, small rounded corners, large rounded cornersā¦always ended up having at least one come off the bed around layer 3-7 and ruin the whole print. This even occurred using painters tape + hair spray.
I did find a solution yesterday though. I added small tabs at the edges which were only 1-2 layers thick which I could tape down to ensure the rest of the print went smoothly. I also jacked the temp up to near 100C on the bed.
Hereās the result (the gaps on the sides are for interchangeable faceplates).
