Designing a carrier board for FEZ Reaper. Would like to know if, in socket D, STAT (PE1) & UD_VBUS (PA13) & JACK_DET (PA14) signals are used internally in drivers for any specific purpose? Are these signals mandatory in any power design for Reaper ? Am planning to use 2 pin terminal block connector for power input. So JACK_DET would not be available in my design. But STAT & UD_VBUS would be available. But should i still use it in design, even if i do not care about the power source ?
@ andre.m - well, for debugging i will use USB Client DP. But for deployment, my carrier board will power up Reaper. My carrier board will also have level shifters for UART, analog signal conditioning and some LEDs for alarm indication.
@ aavinan - The pins you mentioned are not used internally. Your board will startup as long as you apply power and ground. Whether or not you use those pins depends on the requirements of your design.
@ John - thanks
