Snippet - Wait for an Event or Timeout, Whichever Comes First
Simple helper class that allows the user to pause thread execution until some condition is met, with an optional timeout.
Sorry, I don’t understand the use of your class. What is wrong with the default .NET implementation, like this:
        private static ManualResetEvent WaitObj = new ManualResetEvent(false);
            // The LDR button is used to cancel the wait operation in this example.
            InterruptPort myInterruptPort = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.LDR, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
            myInterruptPort.OnInterrupt += new NativeEventHandler(myInterruptPort_OnInterrupt);
                Thread.Sleep(1000);
               WaitObj.Reset();
                Debug.Print("You have 5 seconds to press the LDR button.");
                if (!WaitObj.WaitOne(5000, false))
                    Debug.Print("TIMED OUT!");
                    Debug.Print("BUTTON PRESSED!");
        // Interrupt handler that cancels the wait operation.
        static void myInterruptPort_OnInterrupt(uint data1, uint data2, DateTime time)
            WaitObj.Set();
Sorry for the extremely late reply. I didn’t realize Codeshare had a submission discussion feature until now.
Yes, you’re right! If I had known that particular overload of the WaitOne() method existed in the micro framework, I would not have had to go through the trouble of rolling my own implementation. Doh! Somehow I thought that overload existed in the full framework but was omitted in NETMF. Looks I was wrong.
Thanks for your comment. The built-in method is much more efficient!
