Byron
October 28, 2012, 7:49pm
1
TCP Cellular Radio Driver
Contains extensions and bugfixes to the CellularRadio drivers that let you send and receive data over a TCP connection.
Only NETMF 4.2 is supported, 4.3 will be supported following release and we will likely drop 4.2.
This project is available on Codeplax at https://tcpcellularradio.codeplex.com/ and you’ll need to get the drivers from here.
The maintained project and documentation will remain on Codeplex, this is here as a signpost!
plouf30
December 19, 2012, 5:38am
2
Hi Byron,
Thanks for your Codeshare ! it’s very hard to find information about this module …
I try to use your example code and I have the error
"Error 2 ‘GadgeteerApp1.CellularRadioManager.RadioState’ is a ‘property’ but is used like a ‘type’"
any ideas ?
Byron
December 19, 2012, 6:30am
3
Dear Byron:
I am studying the Cellular Radio module.
I read your documentation on codeplex but still don’t understand how to use your driver.
I download the install file and installed it.
Add the reference GTM.DLSys.CellularRadio to my project.
I see your documentation use CellularRadioManager but when I add
private CellularRadioManager _radioManager;
shows error.
Error 1 The type or namespace name ‘CellularRadioManager’ could not be found (are you missing a using directive or an assembly reference?) F:\GadgeteerGPRSTest(Byron driver)\GadgeteerGPRSTest\Program.cs 21 17 GadgeteerGPRSTest
Byron
March 14, 2013, 11:11pm
5
Hi Tzu,
Please make sure you download the source code and reference that, the installer is out of date and does not include the CeluularRadioManager in any case.
HI Byron:
I have do download the source code but there are 1 sln and 3 projects.
how to reference it?
Byron
March 14, 2013, 11:25pm
7
You can only reference a .csproj file.
So, in your solution, add the .csproj files and you’ll be able to add project references to your project.
I recommend you read the starter guides about NETMF, e.g. http://www.ghielectronics.com/downloads/FEZ/Beginners%20guide%20to%20NETMF.pdf
Thanks, you have 3 projects ,all need to be added?
Byron
March 14, 2013, 11:33pm
9
Minimum required is a reference to CellularRadio_42.csproj
CellularRadioManager.csproj is optional if you want to try it out
Ok, I add CellularRadio and CellularRadioManager. it seem works now.
I will keep try.
I got an error:
what I am missing?
public partial class Program
CellularRadio cellularRadio = new CellularRadio(4);
//cellularRadio.DebugPrintEnabled = true;
cellularRadio.PowerOn(5);
cellularRadio.SendATCommand("AT");
cellularRadio.SendATCommand("AT+CMGF=1");
cellularRadio.ModuleInitialized += new CellularRadio.ModuleInitializedHandler(cellularRadio_ModuleInitialized);
cellularRadio.GprsNetworkRegistrationChanged += new CellularRadio.GprsNetworkRegistrationChangedHandler(cellularRadio_GprsNetworkRegistrationChanged);
void cellularRadio_GprsNetworkRegistrationChanged(CellularRadio sender, CellularRadio.NetworkRegistrationState networkState)
SendDataToServer("test");
void cellularRadio_ModuleInitialized(CellularRadio sender)
Debug.Print("MODULE INITIALIZED");
//cellularRadio.SendSms("0963354403","TEST");
// use
private bool SendDataToServer(string post)
Debug.Print("TcpSend: Connect");
var retVal = true;
if (!_radioManager.Connect("https://www.google.com.tw/"))
Debug.Print("Tcp Send: Connect Failed");
TcpDisconnect();
Thread.Sleep(2000);
return false;
// send data
Debug.Print("TcpSend: Start Send");
if (!_radioManager.SendData(post))
Debug.Print("Tcp Send: SendData Failed");
TcpDisconnect();
Thread.Sleep(2000);
return false;
// wait to flush
string data;
if (!_radioManager.ReceiveData(10000, out data))
Debug.Print("Tcp Send: ReceiveData Failed or empty");
TcpDisconnect();
Thread.Sleep(2000);
return false;
Debug.Print(data);
// ReSharper disable StringIndexOfIsCultureSpecific.1
if (data.IndexOf(@ "HTTP/1.1 201 Created") <= -1)
// unsuccessful server transaction, TODO: re-try?
Debug.Print("Tcp Send: Server FAILED");
TcpDisconnect();
Thread.Sleep(2000);
return false;
// successful server transaction
Debug.Print("Tcp Send: Server OK - \"201 Created\"");
TcpDisconnect();
Thread.Sleep(2000);
return true;
private void TcpDisconnect()
if (_radioManager.Disconnect())
Debug.Print("Tcp Send: Disconnected");
return;
Debug.Print("Tcp Send: Disconnect Failed");
Debug.output
[quote]Program Started
The thread ‘’ (0x4) has exited with code 0 (0x0).
The thread ‘’ (0x5) has exited with code 0 (0x0).
MODULE INITIALIZED
TcpSend: Connect
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### GadgeteerGPRSTest.Program::SendDataToServer [IP: 0016] ####
#### GadgeteerGPRSTest.Program::cellularRadio_GprsNetworkRegistrationChanged [IP: 0008] ####
#### Gadgeteer.Modules.Mekalogic.CellularRadio::OnGprsNetworkRegistrationChanged [IP: 0049] ####
#### System.Reflection.MethodBase::Invoke [IP: 0000] ####
#### Gadgeteer.Program::DoOperation [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 0054] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Gadgeteer.Program::Run [IP: 0020] ####
A first chance exception of type ‘System.NullReferenceException’ occurred in GadgeteerGPRSTest.exe
Error invoking method “Gadgeteer.Modules.Mekalogic.CellularRadio” (check arguments to Program.BeginInvoke are correct)
TcpSend: Connect
#### Message:
[/quote]
Byron
March 15, 2013, 12:59am
12
Please refer to http://tcpcellularradio.codeplex.com/documentation for usage examples.
You need to use CellularRadio OR CellularRadioManager
Thanks Byron:
May be I am stupid. I see your documentation many times , but still not working.
The SMS is works use CellularRadio, but GPRS is not for using CellularRadioManager.
I don;t know the steps for post data.
I put
MyClass();
SendDataToServer("");
in the
ProgramStarted()
I simple test the google in your SendDataToServer() method by
_radioManager.Connect(“https://www.google.com.tw/ ”)
But I get some errors.
TcpSend: Connect
#### Exception System.Exception - 0x00000000 (4) ####
#### Message:
#### System.Convert::ToInt64 [IP: 00af] ####
#### System.Convert::ToInt32 [IP: 0011] ####
#### System.Int32::Parse [IP: 000b] ####
#### Gadgeteer.Modules.Mekalogic.CellularRadio::ProcessATCommandResponse [IP: 01c9] ####
#### Gadgeteer.Modules.Mekalogic.CellularRadio::SerialRead [IP: 0030] ####
A first chance exception of type ‘System.Exception’ occurred in mscorlib.dll
GSM Network Registration Error
The thread ‘’ (0x6) has exited with code 0 (0x0).
#### Message:
GSM Network Registered
GPRS Network Registration Error
GPRS Network Registered
IMEI: 861785000232458
The thread ‘’ (0x5) has exited with code 0 (0x0).[/quote]
Byron
March 18, 2013, 5:12am
14
You need to wait until GPRS Network Registered (NetworkRegistrationState is Registered or Roaming depending on your telco) is printed in your debug stream before you can send data using TCP.
You can’t use those methods directly in the program started method (it will warn you if it blocks for more than 10s).
The radio module (SIM900) can take upwards of 1 minute to power up and register with the network.
Here’s the procedure:
// ctor
public void ProgramStarted()
// for a FEZ Cerberus, using Socket 2, must be type "U"
_radioManager = new CellularRadioManager(2)
DebugPrintEnabled = true,
IsHttpModeEnabled = true
// copy the following methods from the examples on CodePlex
private bool SendDataToServer(string post), replacing YOUR_SERVER_ADDRESS_HERE with your server address (name or IP)
private static void DebugPrint(string str)
Also in the SendDataToServer method above, replace if (data.IndexOf(@ "HTTP/1.1 201 Created") <= -1)
with the correct response for your request. This particular test is expecting a 201 response from a web service.
Then use an event handler, say from a button, to call _radioManager.SendDataToServer("CORRECTLY FORMATTED HTTP REQUEST")
You should then be able to see the HTTP conversation
To get further help, please post your full source code and system configuration (modules, sockets, etc)
Thank you Byron:
I will try it.
Dear Byron:
Still can’t work.
My Setup Spider +radio module + Button.
socket is number 4.
After I see the “GPRS Network Registered”, I push the button to send data.
Debug.print
#### Message:
#### Message:
TcpSend: Connect
Tcp Send: Disconnect Failed[/quote]
Full Code
namespace GadgeteerGPRSTest
_radioManager = new CellularRadioManager(4)
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
void button_ButtonPressed(Button sender, Button.ButtonState state)
DebugPrint("TcpSend: Connect");
var retVal = true;
if (!_radioManager.Connect("www.google.com"))
DebugPrint("Tcp Send: Connect Failed");
TcpDisconnect();
Thread.Sleep(2000);
return false;
// send data
DebugPrint("TcpSend: Start Send");
DebugPrint("Tcp Send: SendData Failed");
TcpDisconnect();
Thread.Sleep(2000);
return false;
// wait to flush
string data;
DebugPrint("Tcp Send: ReceiveData Failed or empty");
TcpDisconnect();
Thread.Sleep(2000);
return false;
DebugPrint(data);
if (data.IndexOf(@ "HTTP/1.1 200 OK") <= -1)
DebugPrint("Tcp Send: Server FAILED");
TcpDisconnect();
Thread.Sleep(2000);
return false;
DebugPrint("Tcp Send: Server OK - \"201 Created\"");
TcpDisconnect();
Thread.Sleep(2000);
return true;
DebugPrint("Tcp Send: Disconnected");
return;
DebugPrint("Tcp Send: Disconnect Failed");
Debug.Print(str);
Byron
March 19, 2013, 10:30pm
17
Hi Tzu, please try again, and this time wait until you see an IP in the debug stream.
Shortly I’ll post my testing configuration here.
Byron
March 19, 2013, 10:38pm
18
I’ve attached a sample application (I’ve also pushed a minor change to Codeplex, that was probably not affecting you, but please update)
Wait until you see the IP:XXX.XXX.XXX.XXX before you try to connect.
Also, please make sure you are setting your access point name (APN) otherwise it will look like it’s working, but actually not be able to use TCP.
Note if you try to GET from www.google.com , they will return a 302 response to your local google, not a 200.
CODE:
joystick.JoystickPressed += joystick_JoystickPressed;
AccessPointName = "vfprepaymbb",
private readonly string _crlf = "" + (char)13 + (char)10;
private void joystick_JoystickPressed(Gadgeteer.Modules.GHIElectronics.Joystick sender, Gadgeteer.Modules.GHIElectronics.Joystick.JoystickState state)
_radioManager.Connect("www.google.com");
var request =
"GET / HTTP/1.1" + _crlf +
"Host: www.google.com" + _crlf +
_crlf;
_radioManager.SendData(request);
var response = "";
_radioManager.ReceiveData(5000, out response);
Debug.Print(response);
DEBUG OUTPUT:
Using mainboard GHI Electronics FEZCerberus version 1.1
Program Started
The thread '<No Name>' (0x3) has exited with code 0 (0x0).
A first chance exception of type 'System.Exception' occurred in mscorlib.dll
The thread '<No Name>' (0x7) has exited with code 0 (0x0).
IMEI: <REDACTED>
IP: <REDACTED>
HTTP/1.1 302 Moved Temporarily
Content-Length: 216
Cache-Control: private
Content-Type: text/html; charset=UTF-8
Set-Cookie: PREF=ID=ca07caef880e295a:FF=0:TM=1363746929:LM=1363746929:S=zNI4HBU-QrLcmHjP; expires=Fri, 20-Mar-2015 02:35:29 GMT; path=/; domain=.google.com
Set-Cookie: NID=67=evenWcDOBxz2aMSsQKyUX9BAa6XN6Aly8FCLwk2WbhEmdeU-A0wHvzw6wmzEYp0tdm51F3v4ZC6d_DVqZ5Z4xRoFfDMI2cd-TDVUwkg6sqR-1NzKPIEQE2qFwGbJ8-xC; expires=Thu, 19-Sep-2013 02:35:29 GMT; path=/; domain=.google.com; HttpOnly
P3P: CP="This is not a P3P policy! See http://www.google.com/support/accounts/bin/answer.py?hl=en&answer=151657 for more info."
Date: Wed, 20 Mar 2013 02:35:29 GMT
Server: gws
X-XSS-Protection: 1; mode=block
X-Frame-Option
Brett
March 20, 2013, 12:43am
19
(aside: Byron, Surry Hills NSW eh? I’m further south and a little west, by 10kms or thereabouts)
Dear Byron:
Thank you very much. You help me so much.
After I try many times, suddenly its works.
Other question is the format for posting data.
For Get you use
private readonly string _crlf = “” + (char)13 + (char)10;
var request =
“GET / HTTP/1.1” + _crlf +
“Host: www.google.com ” + _crlf +
_crlf;
I don’t really understand the request format.
If I have a WCF REST webservice
http://wra.xxx.org/WCF1/Service1/SendCO/{ITEMID_SENSORLIST}/{TIMESTAMP}/{CONCENTRATION}
How could I write the POST request string?
HTTP/1.1 302 Found
Set-Cookie: PREF=ID=11da88e17e0de829:FF=0:TM=1363759270:LM=1363759270:S=iI5uvOpS7JkCD5zR; expires=Fri, 20-Mar-2015 06:01:10 GMT; path=/; domain=.google.com
Set-Cookie: NID=67=jpDwLyWe6riXeIbb_cp0F0BjiWBqKkuPz9_xRNL5YcXAm48eDpHJtsgYk7tFFUC5j1BMww6p9A8y31YKBYpMXsEp79XuaL2RtyJoMx4LFCXGs-IsaBYhgChMDMF1IqNx; expires=Thu, 19-Sep-2013 06:01:10 GMT; path=/; domain=.google.com ; HttpOnly
P3P: CP=“This is not a P3P policy! See P3P and Google's cookies - Google Account Help for more info.”
Date: Wed, 20 Mar 2013 06:01:10 GMT
Server: gws
Content-Length: 222
X-Frame-Options: SAMEORIGIN
302 Moved
302 Moved
The document has moved
here .
