Have an old eBlock piezo you want to use with Gadgeteer? Just get an a breakout module or extender, cut your e-block wire and solder the black wire (ground) to pin 10 on the breakout and the signal wire (usually white or green) to pin 9, you don’t need to connect the positive wire. Then use this code and bam! Or should we say buzzzzzz.
This will eventually be completed to a full Gadgeteer installer package, but figured I would post what I have so far.
Yeah, before I put mine out I looked to see if there was anything similar, and I saw your’s but that it required the eblock module which isn’t listed on GHI’s site anymore. Plus, the breakout boards are cheaper (only $1 each) than the eblock module.
Not sure why the eblock expansion isn’t available any more. Probably just a stop-gap while the channel for modules was filling up. I think almost everything that was available as an eblock is now available as a module, with the exception of the Piezo.
Actually, @ Architect designed a Piezo module, but I’m not sure if he ever offered it for sale:
@ devhammer - Yeah that was one of the first modules.
Settings up a store and start selling my modules is on the list, but unfortunately it is a very low priority at the moment. You never know though, things might change.
