Snippet - G400 RTC get and set time using direct register access
I just posted G400 RTC get and set time using direct register access on Codeshare. Feel free to discuss and make suggestions here.
Thanks for sharing.
can you please explain what the bug is? that this fixes?
@ Jay Jay in my device setup i have a total hang in a call to RealTimeClock.SetTime(xxx)
I am not sure if it is related to the problem described here: https://www.ghielectronics.com/community/forum/topic?id=14931
@ RobvanSchelven - As in the other post, does your behavior change when using a day other than Sunday?
@ James - No, its independent of the date, at least i tested with all dates of this current week.
@ RobvanSchelven - Okay, we will test this case as well.
@ James - Thanks.
Not related to the RealTimeClock but related to the clock (time) maintained in netmf is that on my raptor the clock runs one minute per hour to fast.
@ RobvanSchelven - Thanks for posting this fix. I encountered this bug last night; thought I’d busted my Raptor at first!
There does appear to be a small bug in the posted code, however:
In SetTime, the conversion of the seconds value from datetime uses BCD2Byte rather than
Byte2Bcd.
was:
public static void SetTime(DateTime dateTime)
       UInt32 time = (UInt32)((UInt32)(BCD.Bcd2Byte((byte)dateTime.Second)) +
                                  (BCD.Byte2Bcd((byte)dateTime.Minute) << 8) +
                                  (BCD.Byte2Bcd((byte)dateTime.Hour) << 16));
Changed:
      UInt32 time = (UInt32)((UInt32)(BCD.Byte2Bcd((byte)dateTime.Second)) +
@ Randyrtx - Thanks for the info. I will update the code.
